ok I've had about four starter drive gears to fly apart in the inner primary and they a mess to clean out with all the small springs and gears involved, is there a way to know in advance before one fly apart
I've never had one do that, so other then trying another brand I'm wondering of something else is causing this. Are you certain the bendix is fully retracting from the ring gear when the button is released?
Post a picture of what it looks like if you have one.
well you may have a point i don't use the starter gear lever it's too big of a hassle
Paul
well you may have a point i don't use the starter gear lever it's too big of a hassle i thought with the starter housing needle bearing and the outer primary needle bearing was enough
