Wilwood GP310 Pads?
Wilwood GP310 Pads?
It looks like my caliper banjo bolt was leaking, and my pads are likely soaked with brake fluid. I expect new pads are in order, and I found these:
Does anyone know if these are the correct pads? I've got EBC HH pads on the back already and am satisfied.
I'm also going to shim my caliper over a bit so it's centered over the rotor, I noticed it's tight on one side and a thin washer should do the trick. I tightened up the banjo bolt and have new composite washers if that has not fixed it.
John
John
