Hyper flash issue
Old Yesterday | 05:20 PM
bell927's Avatar
bell927
Default Hyper flash issue
I have led lights with a load equalizer that fixed the hyper flash. I then bought the converter to connect brake and turn signal lights together and the hyper flash came back? The service engine light is coming on, should I worry about it? Has anyone had this issue.
Thanks
Old Yesterday | 07:46 PM
07UltraGuy's Avatar
07UltraGuy
You didn't include year/model info, & the requirements for a load resistor/equalizer can be different between CANBUS & non-CANBUS systems, but I'd remove the first load equalizer and see if it resolves the problem.
Old Yesterday | 07:58 PM
bell927's Avatar
bell927
It’s a 09 Superglide. I will remove the stabilizer and see what happens. Thanks!
Old Today | 05:20 AM
jake24lt's Avatar
jake24lt
You probably cant have one converter in front of another. Custom dynamics make a convertor that will do both things you are trying to do.
GsdGuy
02-06-2023 06:29 AM
JAGlide
07-28-2018 05:59 PM
Rich B.
15
02-06-2013 04:26 PM
RodFarmer
08-09-2009 06:52 PM
jhogan20
03-10-2007 10:34 PM
Quick Reply: Hyper flash issue
