Looking for oil line fitting
I'm trying to find the LONG oil hose fitting that goes in the case vent hole to the left of the oil pump. It looks like a stretched version of the below fitting. Stretched at the NUT. Any help would be appreciated.
https://www.denniskirk.com/v-twin-ma...rd/1913380.sku
Long as we Know you are working on a Case Breather...All Good..
If ya need to, that is just 1/8 pipe fittings...you can do whatever strikes ya...but yes...that elongated fitting is Handy!!
I believe it is in the parts book...but, I aint near one just now
The fitting DK shows is correct size for the actual crankcase breather (lower hole) but needs to be a 45° for a Softail or Dyna, Use a 90° for a Touring model to be totally correct by the book best I remember.
All I've said applies only to a '91 and earlier crankcase including cone side Shovelhead.
PS All those fittings are 1/8 npt (pipe) x 3/8 hose
