Curious starter issue, 98 FXDWG
My buddies bike started make a grinding clanking sound when starting. Not a whine like a starter clutch. I fully expected to find a chewed up jack shaft and ring gear. Instead I see NO wear, no sign of anything wrong. Everything is clean and looks to be working as it should. The jack shaft assembly looks perfect and operates as it should. Bike has 9,000 original miles on it.
Any similar experiences? I’m inclined to replace the starter clutch just to replace the starter clutch.. any suggestions?
Racepres (Yesterday)
It’s not the starter clutch that I can tell.. For whatever reason the starters main shaft gear teeth broke at the tip. Super weird the slivers are clean brakes accross the entire length of the teeth. Whatever made it not want to spin that broke those teeth I’m leaving undetermined and just putting a new starter in. The half opposite the starter where the clutch is spins smoothly and shows no wear. Just weird.
I gotta ask...What Battery you got in that thing???? Thinking it would take some ***, to break them teeth!!!
https://partsfinder.onlinemicrofiche...davidsonmc/283
Would pull the starter apart to give it a once over, cleaning and greasing, parts replacements as as needed, since clutch and pinon gear and some small parts, a lot cheaper than replacing the entire clutch, but would also check the comp to make sure it tight and not worn out as well.
My guess to blow a row of pinion gear teeth, clutch packed up with crap, skipped an engagement once pinion gear engaged the clutch housing ring gear, and what caused the pinon tooth row to be snapped off.
Note, did a write up a while back, on how you can pull apart the starter one way clutch, to clean its parts up to make rebuilding one for a few dollars at most, a lot cheaper than having to buy a new starter clutch instead.
