Best "PAINT-SAFE" degreaser/cleaner to remove oil film?
Old 10-12-2024 | 02:31 PM
07UltraGuy's Avatar
07UltraGuy
Default Best "PAINT-SAFE" degreaser/cleaner to remove oil film?
Rocker box leaks create a hell of a mess, especially when they happen on the freeway.
What's the best cleaner/degreaser to help clean this mess up?
Old 10-12-2024 | 02:50 PM
Ohio HD's Avatar
Ohio HD
WD40 is safe on most all painted surfaces.
The following 2 users liked this post by Ohio HD:
07UltraGuy (10-12-2024), GBHH (10-12-2024)
Old 10-12-2024 | 03:49 PM
TriGeezer's Avatar
TriGeezer
Uhhh..fix the leaks?
But yeah, WD40.
Old 10-12-2024 | 04:00 PM
07UltraGuy's Avatar
07UltraGuy
But yeah, WD40.
Well DUH!
Fixing the leaks doesn't magically clean the film that remains.
Old 10-12-2024 | 04:28 PM
carlgrover's Avatar
carlgrover
I like kerosene for stuff like that.
Carl
Old 10-12-2024 | 04:31 PM
Soundman5000's Avatar
Soundman5000
I have never had an exact leak like that on my Harley but I have purchased many a used car with a dirty engine and I keep my engines clean.
For bad dirty oil covered car engines I have always used Gunk spray can engine degreaser then just wash it off, $6 a can at any auto parts store.
On my Harley I use a concentrated ( mixed stronger than normal ) bucket of warm water and Turtle Wax brand Zip Wax Car wash, $10 Walmart and it mixed strong cuts oil / dirt on a Harley engine and bike very well.
You also have brake / parts cleaner spray but thats a bit stronger than I like to use on a finished surface.
I also recommend S100 engine brightener spray after the Harley engine is clean and dry as it restores the engine black, rubber hoses etc to almost brand new condition.
Even my 28 years old bike engine looks almost new taking these few simple steps. I use that engine bright once a season in-between washes and its great stuff and the ONLY S100 product I like and use. Keeps the blacks black....
The following 2 users liked this post by Soundman5000:
07UltraGuy (10-12-2024), strokelessone (Today)
Old 10-12-2024 | 07:52 PM
RK4ME's Avatar
RK4ME
Normal washing with S-100 and a car wash concentrate has removed any oil on my bikes. A soft brush or a rag wet with mineral spirits would work too. Simple Green or most household spray cleaners would work.
The following 2 users liked this post by RK4ME:
07UltraGuy (10-12-2024), seniorsuperglideE8 (10-12-2024)
Old 10-12-2024 | 08:17 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
Buy a real cheap plastic spray bottle fill with mineral spirits, spray and wipe.
Old 10-12-2024 | 08:20 PM
07UltraGuy's Avatar
07UltraGuy
I got most of it today w/ WD-40 and a wet wash, but I'll probably follow up w/ an engine degreaser/foam spray.
It really is a mess.
Soundman5000 (10-12-2024)
Old 10-12-2024 | 11:28 PM
rizzo's Avatar
rizzo
I use Dawn liquid dishwashing soap at the shop, wet it down with water, spray on the dawn/water mixture and let it sit for 60 then spray it off carefully with a pressure washer. If it's really gunked up, I'll use GoJo hand cleaner and a toothbrush to get at the heavy gunk wherever I can then carefully pressure wash and follow up with Dawn/water spray mixture and rinse again.
If you use chemical cleaners try them on a hidden area first, we've had some situations where it dulled the paint. The Dawn and GoJo are used to clean dishes and hands so their gentle enough to not damage a finish. A coating of wax will bring the paint back on bodywork after cleaning it.
07UltraGuy (10-13-2024)
Quick Reply: Best "PAINT-SAFE" degreaser/cleaner to remove oil film?
