2007 road glide cranks and doesn't start
What's up guys. Would really like some help if anyone has input because I'm at a loss right now. I just picked up a 2007 road glide and I'm having issues getting it started.
The bike ran a couple days ago before disconnecting fairing.
I put fairing back on and plugged in and only one of the head lights work so I definitely misplaced a wire for the headlights. I have pictures down below of the yellow and white wires and there's several connections I can hook it up to, but not sure where.
Full system is all good, no leaks, getting spark and it's showing different codes. Sometimes it says P10118 which I have a temp sensor on the way. Sometimes it says no RSP, and last night it was throwing the u1016 code. Reset ECM and even unplugged and plugged back in. That got me where I am now and it won't ignite, but the ECM code is gone. I had bike hooked up to trickle charger over night with a brand new battery and it still shows not fully charged. Maybe a short?
If anyone has info, wire knowledge, any help would be greatly appreciated. Would even pay a fee if someone knowledgeable wants to get on facetime or something and is willing to try to help.
These are where the headlight small prongs should plug in, but not sure which goes where.
Wire with a tube inside was connected to the positive wire of the USB charger with tape and the positive wire from USB had a circular battery eyelet terminal. Strange..
Not sure where to even start but here goes. If it ran before and doesn't now it's practically guaranteed the problem is something you introduced in the process of removing/installing the fairing. My guess is you didn't take any photos, or notes, or label anything before disassembly so you're going to have to try to remember as best you can how it all came apart. The problem is compounded by the fact that someone has been in there before hacking on the wiring, and don't take this the wrong way but from your post it appears you have very little experience with wiring/electrical systems (all the more reason photos and labeling wires before disassembly is a really smart idea). My best advice is to find someone with some electrical knowledge and wiring experience who can help you out.
This forum is for helping people so they can try to avoid taking it somewhere. The fairing fell off because of the way the previous owner had it set up so I couldn't take pictures. I had my phone ready to go and then the fairing dropped. My fairing wiring issues are related to the headlights. So I was expecting a response of that yellow wire goes here and or someone saying hey, those wires are connected to your ignition in which if you can figure out, the bike might start. Or a hey, the wires to the headlights don't matter for starting the engine. Just looking for some guidance since there's gotta be people here that know about the fairing wiring or willing to try to help because that's the community.
If anyone else is reading this and might have any info to share, would be extremely grateful and would compensate for a phone call if someone knows a thing or two other than telling me to take it somewhere.
I can read a schematic decently, but I've had a hard time finding one that matches.
My apologies if you have more wiring experience than I was inferring from your post. My comment wasn't meant as an insult just trying to help as it appeared to me that you were in over your head.
No, the head light doesn't need to be operational for the bike to run. If you can read a schematic then that's definitely what you should do. Here's a link to the Harley Davidson Service Portal, you can access the schematics and any other service information there for a minimal cost.
I knew this bike had some issues, but it ran when I got it, but ran like ****. Tightened up the exhaust immediately and it would idle good, but would shutter on take off. So that's when the games began. Haha. And I figured that the headlight connections weren't an issue, but start with the simple things. Feels really good when you have a "ain't no gas in it type of situation" so wanted to get that out the way. Haha.
Only code it shows is P0118 and yesterday it threw u1016, but that's gone after resetting ECM. Just the P0118 code is there and I have a new temp sensor coming in mail tomorrow.
It's also weird thou that I literally just sprayed a bit of gas in the throttle body and it started right up. It died immediately, but yeah. There's spark.
Before all of this directly after doing the check valve it would start and run for a couple seconds and shut off.
Also the brand new battery that comes pre charged I installed yesterday isn't wanting to fully charge while connected to the bike thru the night and the trickle charger is good. So it gets weirder and weirder like there's a major ground short and I've been thru everything. No blown fuses and they all seem to get power with a multimeter.
STLCHUCK
Electrical/Lighting/Alarm
09-10-2023 09:48 AM
