Engine noise
Engine noise
I'd like some help. I have a 2005 softtail. I just replaced my cam service kit. I didn't replace the bearings. There is no noise in the rocker arm. There is a tik tik tik noise inside the cylinder. Should I replace the piston ring? Or where is the problem?
The cylinder made a noise and suspected a piston ring.🤔
Although, I don't hear anything unusual, it would be hard to distinguish a noise that is specifically in the cylinder vs.the top end. Remember, the cylinder only goes about halfway up and then you have the heads and rocker boxes above that. Here's a good visual:
To help pinpoint a noise, use a mechanic's stethoscope or press a wooden dowel to your ear and then touch it to various points on the engine.
Although, I don't hear anything unusual, it would be hard to distinguish a noise that is specifically in the cylinder vs.the top end. Remember, the cylinder only goes about halfway up and then you have the heads and rocker boxes above that. Here's a good visual: https://www.youtube.com/watch?v=IH6mMJ9zM2k
Thank you for the good video👍
Two ear mechanic's stethoscope. Under $10 at Harbour Freight. You need both ears plugged from all the exhaust noise to determine engine problems. Compare one cylinder to the other in the same location on each cylinder.
I don't hear any great problem. And I do detect different sounds mixed together that without the two ear stethoscope is confusing.
A broken ring would cause a issue in how it idles. However on a Harley, that's difficult to see.
Do a warm compression check with butterfly held open. See a problem, then double check with a leak down to see if it's rings or valves.
What is a cam service kit?
