2018+ Softail Models Breakout
Clutch Jam Nut
Old 10-05-2024, 07:01 AM
702's Avatar
702
702 is offline
Received 5,847 Likes on 2,393 Posts
Default Clutch Jam Nut
While performing routing maintenance on my Heritage yesterday I ditched the thin jam nut on the clutch adjuster inside the primary in favor of a regular nut (grade 8). Now I can get a much better grip on the nut with either a socket or an offset wrench.
7/16-20 if you want to swap yours out too.
The following 6 users liked this post by 702:
07UltraGuy (Today), FranBunnyFFXII (Today), JimRunningLizard (Today), Lammy1000 (10-05-2024), luckiestiff (10-05-2024), OldMike (10-05-2024) and 1 others liked this post. (Show less...)
Old Today, 09:34 AM
Uncle G.'s Avatar
Uncle G.
Uncle G. is offline
Received 3,773 Likes on 2,023 Posts
I did the same thing on my Evo Heritage Softail years ago. I haven’t bothered with the new bike yet.
702 (Today)
Old Today, 11:25 AM
Powermankw's Avatar
Powermankw
Powermankw is online now
I read this the other day... And was like OK? Then yesterday find that my jam nut came off, and I had to open my case to get it. I tightened it down with the case off... But now I may have a problem getting it off. Torque spec on it is just 10 ft/lbs so basically nothing... But after all that... Duh, put a thicker nut on it.
I have to drain my oil again and put what I want in which I didn't have on hand. I am going to make sure my adjustment is good... And yes, I'm swapping out the stupid nut. Thanks.
702 (Today)
Old Today, 12:05 PM
702's Avatar
702
702 is offline
It's one of those things that only make sense once you do it. Here's a comparison. Much easier to keep a wrench on the thicker nut.
Old Today, 12:08 PM
evildiesel's Avatar
evildiesel
evildiesel is online now
same thing happened to me, lost my clutch one day to find my jam nut missing. it was sitting in the bottom of the primary. i did the same thing as the OP and used a standard width grade 8 nut. havent had a problem since. i wonder if some softails didnt get torqued properly off the line.
Old Today, 01:39 PM
Powermankw's Avatar
Powermankw
Well with me I am the guilty party. I'm the last one to touch it. Again, low torque spec. I know I got at least that... But now, totally uncertain my nut isn't coming off. With rotating machinery, there are usually safeties. Can't be that big of an issue, but you would think they could make it more secure.
stevepacman
2014-2023 Touring Models
15
07-11-2024 12:04 PM
nadajoey
03-29-2021 12:42 PM
BBD2112
02-24-2017 02:27 PM
Tedjay
05-26-2014 05:47 PM
kiethf
06-13-2012 06:30 AM
Quick Reply: Clutch Jam Nut
