General Topics/Tech TipsDiscussion on break in periods, rider comfort, seats and pad suggestions. Tech tips as they become available will be posted here.
I removed the entire EFI on my 2007 Dyna. Went with a Mikuni & Thunder Heart Stand Alone Ignition. Runs like a locomotive . . . ON STEROIDS! HOWEVER, I threw every Error Code in the book. Had that damn Check Engine light on and couldn't figure out how to get rid of it. Then a brain storm. Remove the speedo and carefully remove the top chrome bezel. Carefully remove the pointer, pull straight up. Lift out the face plate disk. Find the little LED that's under the ABS light. Stick a small piece of black electrical tape on it. Carefully reassemble. Turn on ignition. Wa La ABS light is GONE.
Thank you for the replies. I started to disassemble it this morning. It looks like it can be done. However, the forums did not mention that as a procedure. Was your Speedo like this one?
