96 Lowrider electrical question
Old Today, 08:01 AM
Magnut1's Avatar
Magnut1
Magnut1 is offline
Received 1,724 Likes on 843 Posts
Default 96 Lowrider electrical question
I just bought this bike for $1500. Needs battery and some module under the square chrome cover on the left side. Can anyone tell me what is behind that chrome cover? Story is the battery died and was attempting to jump it but switched to Start on the charger. He smelled smoke and quit jumping. Says burnt smell coming from under the seat in that box. Also anyone use a front fender tip piece. There are some paint chips and want to cover them. There is one on eBay for $30
Old Today, 09:42 AM
hattitude's Avatar
hattitude
hattitude is online now
Received 8,226 Likes on 4,421 Posts
Don't be surprised if you need more than two parts.
I suggest you get a factory service manual for that bike. You will probably need it before this repair is done.
The "chrome square cover on the left side" is the coil cover (forward) and/or the electrical panel cover (aft).
I suspect some of the parts under the electrical panel were cooked...
You should check the fuses under that electrical panel cover, to include the starter relay at minimum. Hopefully you didn't also fry the #32449-95C Electric continuity module, as I believe it was $300, when it was still available... I don't know what they are using now.
Hopefully you are good with a multi-meter.
Good luck with your repair, and report back what you find and need to fix...
Old Today, 09:45 AM
Max Headflow's Avatar
Max Headflow
Max Headflow is online now
Received 5,991 Likes on 4,054 Posts
The ignition module and turn signal module are under that cover along with the fuses.. You got a pretty good deal even if the electrics are fried..
hattitude (Today)
Old Today, 09:50 AM
Suede Blue Man's Avatar
Suede Blue Man
Suede Blue Man is offline
$1500 bucks, sounds like the steal of the day
hattitude (Today)
Old Today, 09:56 AM
Max Headflow
FWIW if the ignition module is fried, I'd replace it with a nose cone ignition. I'd also with the TS module, if blown. go with aftermarket.
May end up being all the electronics plus a battery but at 1500 OP came out ahead providing the motor and tranny are in good shape.
When you get smoke like that it's possible that the jumper was connected backwards.
hattitude (Today)
LOTO
Dyna Models
02-04-2022 09:03 AM
Heat Wave
10-04-2021 06:46 PM
Just Plain Cody
07-07-2010 06:15 PM
kpreese
11-28-2006 12:01 PM
atrox88
03-27-2006 05:39 PM
Quick Reply: 96 Lowrider electrical question
