2024 Street glide Kahuna grip quality
Hello everyone!
I know with the stock grips if you ride without gloves they get sticky (and I cant wear gloves because when I do, due to an injury in my left hand the glove starts hurting my hand) and with this past summers heat my grips literally started melting (I'm in Florida in an area that consistently got over 100) I have been looking at grips and the only ones I came across that I liked were the Kahuna (not heated) grips from Harley I was wondering if they were worth getting or if the rubber on those would just degrade like the stock grips have, This is the first bike I have had that has Rubber grips my previous Harleys all had metal grips. Thanks in advance!
my buddy had Kahuna heated handgrips as OEM on his 22 CVO RG...they apparently weren't installed properly to slide all the way to the end so a small portion of the end was unsupported by the handlebar, and being rubber near the end, it split from just putting pressure on the grip getting on and off the motorcycle..they did replace under warranty but be sure to slide these all the way on to avoid damage
