Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
Getting parts ready for a winter build. Going 98 on my 88 low rider. My question is do I need to replace the cylinder studs? I understand the torque sequence however are they torque to yield from the factory? If so wouldnt they be one time use?
When I went to 98 on my 88 I reused the studs. 50k later I went to 95" and used them again. I did go to the newer style nuts that look better. Shops will quote you replacement. I am sure there is a sgtretch factor at some point.
