problem adjusting clutch cable
Simple things that many forget:
Ensure there's slack in the cable.
Ensure the ramp assembly is properly indexed before installing the cover- the correct placement will show more of the cable extended inside the trans cover.
Back off the adjuster screw in the primary.
Then follow the factory procedure.
Spider0408
11-06-2017 09:37 AM
00glider
05-20-2006 10:58 PM
