Battery/starter/comp?
Old 09-20-2024, 02:28 PM
gt06's Avatar
gt06
gt06 is offline
Default Battery/starter/comp?
So I just noticed since yesterday that when I start my bike there’s a hesitation/ stoppage and then it continues to turn over to start. Before, I’d hit the start button and it would just wind over until it started but now it engages but stops for a very brief moment then continues to turn over until it starts. Only thing I’d done to it was to down load a new tune to it. I just received a new Dynojet Power Vision yesterday and although I don’t think that has anything to do with the issue is it possible?
NELS (Yesterday)
Old 09-20-2024, 02:44 PM
Taxgod4u's Avatar
Taxgod4u
Taxgod4u is offline
Received 1,306 Likes on 594 Posts
Since you dont list the bike details my wag is that you did not turn on the ("ACR") automatic compression releases on install of tune. that or battery lost a cell.
The following 3 users liked this post by Taxgod4u:
harpwrench (09-20-2024), TriGeezer (09-21-2024), WP50 (09-21-2024)
Old 09-20-2024, 03:17 PM
HD_noobie's Avatar
HD_noobie
HD_noobie is offline
Sounds like a weak battery, test that first.
pgreer (09-20-2024)
Old 09-20-2024, 03:18 PM
ChromeJunkie's Avatar
ChromeJunkie
ChromeJunkie is offline
Received 4,196 Likes on 1,828 Posts
I had basically the same thing on my 06 FLSTC, except this time, it would basically just turn the engine over slightly then just click. I took the battery and had it tested and it was good, so I replaced the ground cable on the battery and now all is well. Hopefully, it will be something simple. Good luck.
Old 09-20-2024, 03:49 PM
gt06's Avatar
gt06
gt06 is offline
Sorry it’s 2014 CVO Ultra limited and the only mods it has is a full system Vance and Hines Power Duals. Still has the original SE 110 Air Cleaner. There wasn’t any lead up to a battery issue but then again a first time is technically a lead up right.
Old 09-20-2024, 03:50 PM
gt06's Avatar
gt06
gt06 is offline
I bought the bike used a few months ago and I have no idea how old the battery is.
Old 09-20-2024, 04:09 PM
Vec's Avatar
Vec
Vec is offline
it needs a new battery 🔋
Max Headflow (09-21-2024)
Old 09-20-2024, 09:04 PM
gt06's Avatar
gt06
gt06 is offline
Pulled the battery tonight so I can take it to the dealer in the morning to have it load tested. Worst case is just over $300 for a new battery.
Old 09-21-2024, 05:49 AM
Tjroadie's Avatar
Tjroadie
Tjroadie is offline
Better options for batteries than a dealership! Just sayin
Old 09-21-2024, 07:46 AM
Rounders's Avatar
Rounders
Rounders is offline
Received 2,285 Likes on 1,812 Posts
In US batteries are a lot cheap, unless you are buying lithium.
I have had good luck with dealer batteries, so I run them. I am sure any name brand is good.
Quick Reply: Battery/starter/comp?
