load equalizer
Received 21,979 Likes
RANGER73 (Today)
Steady state LEDs are no issue, it is the blinking rate that is affected when you go from incandescent to LED that is the issue, different resistance for the blink rate. BCM should compensate as you have a CAN bus wire system. Turning the 4 way flashers on will let the BCM compensate for the resistance change.
I knew there was a way. The BCM will learn if you follow the advice given.
Freak Show (Today)
