New Voltage Regulator
Infidel 1975 (Today)
The throttle by wire can learn a new idle position...
For example, if you turn off your bike with the kill switch, and you slightly turn your wrist when reaching for the kill switch, you may increase the throttle position a little bit right at the moment of shut down. The ECM will remember that position.
Do that like 10 times, and all of a sudden you realize your idle is at 1300-1400 rpm...
A throttle position reset, will zero the throttle position and the idle will go back to whatever the tune calls for...
You sometimes have to do the reset procedure a couple times for it to take...
OP-
There's no guarantee the throttle position reset will cure your issue. It is a good first step however, when trying to diagnose a high idle rpm. It has fixed many a high idle issue.
Give it a try and report back if it helped.
NOTE: I have heard to wait until the engine light shuts off, and I have heard to wait 10 seconds... Sorry, too lazy to make the walk to my garage and look it up..
Here is how I saved it in my notes;
Don't touch the throttle .. kill switch in the run position ...
Turn ignition switch on, wait for engine light to go off, turn ignition off.
Do this 4 times, then start the engine. This resets the computer.
Note: when shutting down the engine make sure it's at idle. Don't blip the throttle, and don't shut it down on cold idle. The computer remembers the last rpm at shutdown and sets the idle to that.
Rounders (Today)
