REAR CYCLINDER SPARK PLUG CARBON BUILDUP
Old 09-19-2024, 09:06 AM
gator91384's Avatar
gator91384
gator91384 is offline
Stage II
Default REAR CYCLINDER SPARK PLUG CARBON BUILDUP
My '02 Fatboy starting running rough and on idle engine quit. It would start back up but felt like it was running on one cylinder. Removed the plugs and the rear was black with carbon build up. Front plug was fine. Air Filter was very dirty. Installed new plug and kept filter off and started up and engine still felt like it was running on 1 cylinder. Pulled rear plug and it those few secs of running carbon was starting to build up. I had spark and wires with volt meter and wires were fine. It has all the symptoms of fuel injection issue but pulled the injectors, tested with volt meter and both between 15.8-16.1 ohms. Cleaned injectors and did not notice any issues with the flow on both injections so I don't think that was the issue. Was thinking it might be a dirty fuel filter but I suspect both plugs would read the same, not just the rear. Any suggestions before I pull the fuel pump and filter?
Old 09-21-2024, 04:26 PM
Max Headflow's Avatar
Max Headflow
Max Headflow is offline
Received 5,978 Likes on 4,045 Posts
Swap injectors.
Old Yesterday, 11:13 PM
Spanners39's Avatar
Spanners39
Spanners39 is offline
Did you clean the rear plug or replace it?....I never clean plugs on Harleys, just replace because once fouled they never come right again.
gator91384
09-18-2024 08:29 PM
Zannarack
EVO
06-12-2020 08:31 PM
chuckw2
04-14-2013 09:29 PM
Titan56
03-19-2010 11:58 AM
bob53
08-18-2008 08:16 PM
Quick Reply: REAR CYCLINDER SPARK PLUG CARBON BUILDUP
