New Recall / 0186 Center Cooled Regulator
Note: All Caps as recall was presented this way.
RCL:MY24 CENTER-COOLED REGULTR
RECALL DATE: 2023-09-15
THE REGULATOR OUTPUT WIRE (RED WIRE) MAY RUB ON THE FRONT CORNER OF THE CRANKCASE. OVER TIME, THE WIRE INSULATION MAY WEAR, EXPOSING THE WIRE AND POTENTIALLY CAUSING A SHORT TO GROUND.
REMEDY
THE RECALL REPAIR WILL INCLUDE INSPECTION OF THE VOLTAGE REGULATOR OUTPUT WIRE HARNESS AND INSTALLATION OF A SECONDARY RETENTION STRAP. ALL VEHICLES WILL HAVE A SECONDARY RETENTION STRAP INSTALLED TO ENSURE PROPER WIRE ROUTING. IN THE UNLIKELY EVENT THAT DAMAGE TO THE VOLTAGE REGULATOR OUTPUT HARNESS IS FOUND, A RECALL KIT CONSISTING OF A WIRE HARNESS EXTENSION WILL BE INSTALLED TO REPLACE THE DAMAGED WIRING HARNESS PRIOR TO THE INSTALLATION OF THE SECONDARY RETENTION STRAP. OWNERS OF AFFECTED MOTORCYCLES WILL BE ADVISED TO ARRANGE SERVICE WITH AN AUTHORIZED HARLEY-DAVIDSON DEALER, WHO WILL PERFORM THE REMEDY AT NO CHARGE TO THE CUSTOMER.
REMEDY
The following 6 users liked this post by dobbz:
Beartooth Rider (Yesterday),
BrandonSmith (09-17-2024),
Ducman82 (09-16-2024),
Erratikmind (09-17-2024),
Frirish (09-16-2024),
and 1 others liked this post.
Received 4,898 Likes
The following 3 users liked this post by bill from tn:
I'm heading down today to see if I can get it scheduled for this week
I've been told the hardware 'kits' will start shipping 10/14...so until then either DIY inspection or have dealership perform one and if any concerns to address as best as one can until the HD solutions are available
drc68 (Yesterday)
mjwebb (09-17-2024)
I crawled under my bike to look but it was all black caked road grime underneath from 15,000 miles so aborted the inspection
