DK Discrete, External Breather System, catch can
I installed the DK Customs EBS today on my RG3. It installs pretty easy, had to drill a hole in the metal backing plate to run the hose through. I drilled the hole where I thought was best to run the hose unseen under the tank.
Drilled the hole .010 inch smaller than hose diameter for a tight fit for no leaks. Calibers or micrometer required for that.
No more hot oily fumes entering my intake.
Why did I wait?
Opening the package from DK I must of damaged the spare Catch Can O-Ring, They graciously sent me TWO more and some stickers and a cool cleaning towel free.
Completely satisfied with the Discrete kit. Took a couple of pics, Catch Can might be a little low, we’ll see how it goes. Easy to raise it up.
Mike
How I decided to install it, doesn’t block intake.
Almost invisible easy installation.
Why not install a sticker inside
DK Catch Can
Sleeper SE K and N, now with DK Discrete EBS
Runs good
Why did I wait?
Mike
DK Catch Can
Runs good
The following 4 users liked this post by MikeRG3:
Nice job. I have a similar setup on my 2018. I am wondering if others who have this DK (or other) Catch Can find it filling up and spraying dirty oil/water onto the bike. If I do not remove and clean mine every 700-1000 miles, it becomes a real mess.
I am careful to not over fill with engine oil.
If others experience this, have you found a fix of some kind or do you just remove and clean frequently?
DK Custom Transformer EBS
I went with the DK Billet Aluminum Transformer EBS into the K&N Mini Pod Filter. For me this is the finest performer and absolutely the greatest looking cleanest install.
This is topped off with the Outlaw HiFlow 606 Air Cleaner System. Along with a perfect look, this is a “real” performance set up.
https://www.hdforums.com/forum/tri-g...to-filter.html
DK Custom (09-14-2024)
