New M8 128 Build dripping oil from the throttle body
I have an issue that i can wrap my head around , this is a brand new build that i assembled myself and did everything by the book and double checked everything and everything looks fine and the motor sounds healthy . its band new everything .
- welded balanced crank , carrilo rods
- 128 BB A1 kit 11:1
- Stock heads (had them fully refreshed)
- crankcase breather, vented dipstick , vented AC.
- fueling umbrella valves.
- full s&s cam chest w/57x cam (shop67)
- SC pushrods.
- s&s rocker studs
and the list goes on.
every gasket, every bolt , every oring has been replaced on everything a spared nothing.
and for the most part i have no leaks nothing abnormal, got a FM base map in it just to heat cycle it and oil pressure looks good @60psi on startup and the bike idles and sounds great and healthy
i unbolted the entire AC to check if the breathers are pushing oil into the TB but looks dry and the oil is coming out of the TB only but the intake manifold looks dry.
i just dont know why when i turn off the bike after a short heat cycle i see some oil coming out .
its really annoying the hell out of me i spared nothing on this build trying to make it as clean as possible.
hoping someone can get to the bottom of the because im out of ideas
- SC pushrods.
- s&s rocker studs
- SC pushrods.
- s&s rocker studs
- SC pushrods.
- s&s rocker studs
orings looks fine plus its a brand new SE 64mm intake/TB
my concern is that how would the TB drip oil when the head breathers are not even connected to the TB . it feels like its coming thru the intake but only when the bike gets turned off
Could be residual oil from the build working its way out.
Even on a careful build there is no guarantee of a 100% oil free intake. You can add a new VVT trans cover won't hurt and then it's possible to block the breather holes in the heads and not use your expensive breathers.
Like stated, make sure your oil level is no more than 1/2 way on the dipstick.
So, you have a vented trans cover, the Harley 2024 VVT cover has an oil separator but probably not a solution. Sounds like you have it all covered, what I wrote is all I’ve got. I’d run it and let things like rings and valve seals seat. I wouldn’t say you have a problem since we don’t know how much oil you’re talking about.
im honestly suspecting the same this that the rings haven't seated yet because the bike hasn't really seen any high rpm just idles up to temp right now . hopefully here in a couple of weeks when it hits the dyno it will see some load and i will definitely monitor it
