2026 Dyna Street Bob doesn't start
Old 09-10-2024 | 06:19 PM
hdaus77's Avatar
hdaus77
New Member
Default 2026 Dyna Street Bob doesn't start
I have a 2016 Dyna Street Bob, which has not been ridden for a month or so now due to TX heat.
I didn't have it on battery tender for 3 weeks or so and then I added it.
However my bike doesn't start now.
I did some search and it looks like keyfob is the most common cause, so I ended up replacing the batteries on my keyfob....that didn't fix it.
What are some common causes? Any tips on troubleshooting/resolution?
Attaching a video of what it sounds like when I try to start.
File Type: mov
Old 09-11-2024 | 01:06 PM
nevil's Avatar
nevil
The heat may have killed your battery, so get it load tested. That's the most common cause. After that, it's loose or dirty battery cables, especially the ground to frame. You should also check for codes.
I can't play the video, it wants to use some app I don't have or want.
hattitude (09-12-2024)
Old 09-12-2024 | 10:27 AM
2500hdon37s's Avatar
2500hdon37s
Definitely a bum battery.
Just go ahead and replace it, no sense in trying to charge it up and limp along only to get stuck somewhere.
Old 09-12-2024 | 10:33 AM
jake24lt's Avatar
jake24lt
The 2026 Dynas are out early!
Nazgul
The General Motorcycle Forum
08-13-2024 12:57 AM
Cafard
Motorcycles For Sale
11-09-2015 02:58 PM
streetboy80
05-20-2014 01:40 PM
Lippi
04-23-2010 03:08 AM
WdGldDave
10-31-2006 12:18 AM
