Oil change after lifter and cam failure.
Hey Guys, just got my 15 CVO Road Glide Ultra back from harley after lifter failure. They replaced cams, lifters, cam plate, oil pump, bearings, and oil pan.
. Then said they flushed all 3 tanks. And replaced all 3 holes with HD SYNTHETIC. When I asked should I change motor oil when I get home (80 miles) they said no reason too. Now in my mind, I can't imagine that they were able to remove all the metal shavings.
. Am I right....? Just for peace of mind if for no other reason.
Thanks Jim
Thanks Jim
Road glide 59 (09-10-2024)
The following 2 users liked this post by Max Headflow:
harpwrench (09-11-2024),
Honestly there's no way of knowing if there's some remnants in the motor somewhere. A friend went through the same, and a year later had a small piece of steel make it's way into the oil pump. That was after a few oil changes. The only way to be sure is a complete tear down of the motor. So I would just ride it, and when you change oil, open the filter up and look for crap in there.
The following 2 users liked this post by Ohio HD:
Not sure why they felt the need to flush the Tranny and Primary? Change the fluids out? Sure, but a full flush out? Or am I missing something?
The oil cooler should have been the first thing to hit the scrap bin, there is no affordable way to thoroughly clean a motorcycle oil cooler after an engine failure.
After a lifter failure, the cases should have been split.
