Lubrication problem .
98 evo fxdwg. My friend had oil leak problem and didnt quite seize motor but may as well have . Well i replaced cylinders , rings , pistons , and heads. Also rebuilt oil pump . New keys , and gears . Heres my issue i seem to be getting plenty of oil to crank because when i pull timing plug at bottom of front jug left side and turn engine over it pukes oil out the hole. But i remove valve covers from rocker boxes and see no oil to valvetrain. Any help or suggestions would be appreciated. Has to be something im overlooking . .
Received 23,966 Likes
justgliding99
Oil Archive (no new posts)
08-15-2018 07:24 PM
