Well looks like my Stator crapped out
I have did the research on her about stator issues ...so I know to also go ahead and change out the VR ...so now it comes down to which one I need to buy....I have a 2014 Road King with the 103ho (I don't know if that even matters) and I also run a bluetooth amp and 4 speakers...and it has ran flawless like that for 3 years....just put in a new Deka battery last month....
So I have been looking at Cycle electric,Harley,and Drag Specialty...looking more towards Cycle electric....any advice would be appreciated....TIA
I would go with OEM or Cycle Electric.....
Nothing really wrong with OEM, but between the two of those, I would go with Cycle Electric.
Great company, great products, and really good customer service.
Besides, their replacement for your VR (#CE-608) hangs from the upper cross member on the front frame down tubes. That keeps it up and away from the oil cooler and the heat it radiates. That should help it last longer..
Crashrdking01 (09-09-2024)
My stock voltage regulator on my 08 road king went 75k and my stator went about 80k...yup probably should have just done them both at the same time but the regulator went out while I was in laconia a few years back. I changed it in the dealers parking lot and I don't think I had enough tools to do the stator with me lol. I guess my point is the stock ones were pretty reliable in my opinion. I've also heard great things about cycle electric and I'd probably go that way in future if the need arises.
https://www.ebay.com/itm/14342707086...mis&media=COPY
Well I went with this Stator and I'm wondering is this the best VR to go with ? https://www.lowbrowcustoms.com/produ...and-flt-models
https://www.ebay.com/itm/143427070865?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=V8lCPjD-TAy&sssrc=4429486&ssuid=3P-rsaHdQXy&var=&widget_ver=artemis&media=COPY
"A more efficient approach to rectifying regulators.
To control voltage on Harley-Davidson alternators other rectifier regulators dump current to ground. This causes maximum stator current and temperature at all times. Cycle Electric rectifying regulators block current to control voltage. This reduces stator current resulting in lower temperature and less drag on the motor which means more efficient operation. The largest and most noticeable benefit is a smoother charge to the battery. This means less battery maintenance and longer battery life."
You have not compared, in person, the Cycle Electric to the HD one have you. The windings on the Cycle Electric ones are heavier gauge than the HD version. The regulators are more efficient than the HD ones.
Buy the CE regulator for the stator. I would call or email CE if I was not sure what regulator to use with their stator.
