Counter Sunk Rotor Washers
Old 09-06-2024, 10:10 AM
Racepres's Avatar
Racepres
Racepres is offline
Received 2,338 Likes on 1,683 Posts
Default Counter Sunk Rotor Washers
New one on Me...
Anyone know what Madels used a counter sunk toothed washer to mount front rotor???
TIA
Old 09-06-2024, 02:56 PM
t150vej's Avatar
t150vej
t150vej is offline
Received 1,813 Likes on 1,176 Posts
No Evo came from factory like that. 5/16' button head with blue lock patch or 242 is the prescription.
Maybe someone just couldn't stand the thought of no lock washer.
Racepres (09-06-2024)
Old 09-07-2024, 07:29 AM
Bubba Zanetti's Avatar
Bubba Zanetti
Bubba Zanetti is offline
Received 14,298 Likes on 6,115 Posts
Where’d you see this at?
Old 09-07-2024, 10:04 AM
Racepres's Avatar
Racepres
Racepres is offline
I think I found it...My Eyesight is Off... 3/8 counter sunk...Not all Rotors are Flat..I have more than a couple here with counter sunk rotor Fasteners.. I will peruse the Parts Fiche..maybe find those Locking washers...
@t150vej I never thought there was much difference in Shovelhead vs Evo rotors.....certainly Not Early ones..But..I do Not pay that close attention...Mix and Match at my place..
Old 09-08-2024, 04:30 PM
98hotrodfatboy's Avatar
98hotrodfatboy
98hotrodfatboy is online now
Received 5,409 Likes on 3,617 Posts
3/8" is a rear rotor not a front.. Fronts use a 5/16"..
Old 09-08-2024, 05:11 PM
Racepres's Avatar
Racepres
Racepres is offline
Yes...Correct...I just noticed, depending on the Caliper..some FXR's and I bet others, used those CounterSunk fasteners.. Heads flush with Rotor Surface..
Now..What was the Deal with the Darn Toothed Washer???
Old 09-08-2024, 05:21 PM
98hotrodfatboy
The only time I ever seen counter song screws for the front rotors were with aftermarket rotors and I even had one on my Fatboy.. The rim was aftermarket that had a wider hub.. It was a large spoke 18" rim where I had to use a rotor that had a quarter inch offset on it and that had the countersunk screws..
Old 09-08-2024, 08:05 PM
Racepres's Avatar
Racepres
Racepres is offline
Dual Disk and Pie Slice caliper applications into the late '70's. On into the '80's on FXR's at least
But... What 3/8 Countersunk Rotor Bolts used Lock Washers????
Old 09-08-2024, 10:24 PM
s-glide76's Avatar
s-glide76
s-glide76 is online now
Received 1,086 Likes on 439 Posts
My 82 FXRS has dual disks with countersunk screws. No lock washers.
Old 09-08-2024, 10:38 PM
Racepres's Avatar
Racepres
Racepres is offline
Right... But, I am Inquiring about 3/8, Rotor, Counter sunk fasteners, with a Locking Washer.. Rear... Unless yer turning a Rear into a front on an early Touring Bike... BTDT
Quick Reply: Counter Sunk Rotor Washers
