Stripped belt pulley bolt
First thing NEW nut , next using something like a dental pic remove as much of the smeared nut material as possible If you have access to the right size die try to start it on from the non lead in side to finish cleaning up the threads If you cant get a die, buy two nuts and make a thread chaser out of one. the shaft is harder than the nut and that is why the threads pulled from the nut and not the shaft Install new nut and get out the torque wrench and let us know
Goose_NC (09-06-2024)
Received 49,811 Likes
Max Headflow (09-06-2024)
If you are able to clean out the threads on the main drive gear...
Replace the sprocket, spacer, quad seal, sprocket nut, lock plate and screws, big oil seal.
Available as a kit, part number: 40210-85D.
Don`t reuse any of that old hardware, or you will be doing this job again.
Instructions sprocket kit
nsdhoward45 (09-07-2024)
Agreed. About the only way to clean that up would be to use the proper pitch thread file, place the tranny in gear and spin the main drive gear off the mainshaft. Use a socket and drill adapter/drill. There may be enough threads there for the file to follow.
It don't look to good tho. Probably needs a new main drive gear.
Uncle Larry (09-13-2024)
fergerburger
Shovelhead
06-12-2021 10:33 PM
