2016 Road King can’t find neutral
Old 09-03-2024, 12:28 PM
Badbagger's Avatar
Badbagger
Badbagger is offline
Default 2016 Road King can’t find neutral
So been riding for 40 years this **** is insane. Changed fluid out in all 3 holes but I’ll be damned ****in neutral is no where to be found!!! Wtf really and yes new to me bike. Bat **** crazy.
Old 09-03-2024, 12:32 PM
Rounders's Avatar
Rounders
Rounders is offline
Received 2,247 Likes on 1,779 Posts
If it has cable adjust. Practice. Only one oil effects shifting.
Obviously it's there.
Old 09-03-2024, 12:33 PM
brakeless's Avatar
brakeless
brakeless is offline
Received 5,675 Likes on 2,717 Posts
Hydraulic clutch? What amount of Primary fluid did you put in? Did it do it before? If so, what changed?
Old 09-03-2024, 01:15 PM
cowboydoc's Avatar
cowboydoc
cowboydoc is offline
Received 1,142 Likes on 468 Posts
Could you find neutral before the fluid change? If yes then most likely you overfilled the primary.
This is what the level should be:
The following 2 users liked this post by cowboydoc:
bklynbob (09-04-2024), brakeless (09-03-2024)
Old 09-03-2024, 01:30 PM
brakeless's Avatar
brakeless
That's where I was headed with my questions. Too many times I see the Primary overfilled by attempting to hit that mark visually. It can be difficult at times to have the bike perfectly level and upright. Sometimes it's easier to fill with the exact amount specified under "Capacities". If it says 26 oz, put in 26 oz.
Old 09-03-2024, 02:04 PM
Badbagger's Avatar
Badbagger
I figured out a way to find it, all is well thanks.
Old 09-03-2024, 02:05 PM
brakeless's Avatar
brakeless
Sharing is caring. Just sayin...
Old 09-03-2024, 02:53 PM
The Big Papa's Avatar
The Big Papa
The Big Papa is offline
What did you do? Read the manual, or swear more...
Old 09-03-2024, 09:29 PM
Rounders's Avatar
Rounders
Rounders is offline
Originally Posted by brakeless
T Sometimes it's easier to fill with the exact amount specified under "Capacities". If it says 26 oz, put in 26 oz.
I just dump what the manual says. Maybe if I had primary off I will look, but manual has a number for that.
I am not 100% convinced overfilling effects this. I have had primary filling up with engine oil, and shifted ok. Lots of the old evo guys with bad casting had it to, and they did not happen to mention neutral issue either. Though never asked them.
I think it is more about practice.
Old 09-04-2024, 05:02 AM
roussfam's Avatar
roussfam
roussfam is offline
Received 7,199 Likes on 3,741 Posts
Operator error?
Germansheperd (09-04-2024)
Quick Reply: 2016 Road King can’t find neutral
