stator 'half-dead'?
Old 09-01-2024, 09:01 AM
b0fh's Avatar
b0fh
b0fh is offline
Default stator 'half-dead'?
Today out of the blue (pretty sure bike was normal last time I rode it) my '13 ultra showed low voltage. normally it would be pegged at ~14 in the panel but now it drops as low as 10 at idle, and goes up as the RPMs go up.
Back to home I go, unplug the stator wires, no short to ground, ohms read normal, however the voltage it puts out on all coils is only 7.2-ish at idle, way lower than normal. is it a thing for a stator to be 'half-dead' like this, no shorts or opens but low voltage out of the blue?
no time to fix it myself so I guess off to the mechanic it goes tomorrow... sigh.
Old 09-01-2024, 09:41 AM
Rounders's Avatar
Rounders
Rounders is offline
Received 2,240 Likes on 1,774 Posts
What is the AC output of stator? That should go up to around 80 volts AC when revved up.
Dc also involves volt regs, which converts AC to DC. I had bad plug limit it to 10 volts.
Old 09-01-2024, 09:43 AM
Rounders's Avatar
Rounders
Rounders is offline
How many miles on bike? With primary off i would replace primary bearing and tranny shifter seals if it hasn't been done before.
Not that I am convinced it is stator, with out knowing ac out put
Old 09-01-2024, 09:59 AM
im's Avatar
im
im is offline
A stator produces AC voltage.
A regulator converts AC to DC voltage.
Based on the limited information..
Consider review of battery and regulator.
Old 09-01-2024, 10:13 AM
Rounders's Avatar
Rounders
Rounders is offline
I kinda doubt battery unless just shot. But not sure. But batteries fail the most often.
Check AC out is best. But it can PIA getting at plug depending on year
Old 09-01-2024, 12:11 PM
TriGeezer's Avatar
TriGeezer
TriGeezer is offline
Received 30,771 Likes on 11,577 Posts
That seems to say he is measuring output of the stator.
So,op…is that AC voltage from the stator?
Old 09-01-2024, 12:33 PM
LQQK_OUT's Avatar
LQQK_OUT
LQQK_OUT is offline
Received 1,644 Likes on 1,122 Posts
Check voltage regulator. If defective, replace with a Cycle Electric one.
https://cycleelectricinc.com/RECTIFIER.html#CE-600
This past March, on a lunch run I noticed the needle jumping a bit on my voltage gauge. A little while later, it would read normally. After lunch my 2011 Ultra wouldn't start. Friend had a jump pack and we got the bike started, Ram some tests when I got home and everything tested out OK. I wasn't convinced. Ordered and installed a Cycle Electric CE-607 voltage regulator and haven't had a problem since then. Bike had 218,580 miles on it when I replaced the original voltage regulator. I have over 20,000 on the new one without any problems. When I see/experience a strange electrical problem, I try to track it down and repair it. FYI, I'm still running with the original stator on the bike.
Once again poor advice given by this member!
I believe the stock stator is rated at: 6-23 VAC per 1000 RPM (check your service manual)
Run the engine at 2000 rpm. The VAC output should be 32-46 VAC.
Old 09-01-2024, 12:48 PM
b0fh's Avatar
b0fh
b0fh is offline
7.2vac at idle (1000rpm). according to spec it should read a minimum of 16.
and yes that is the stator (disconnected, bike running on battery only)
Old 09-01-2024, 12:50 PM
b0fh's Avatar
b0fh
b0fh is offline
on the dc side, it reaches the expected 14v (dc, on panel) only when approaching 3000rpm
Old 09-01-2024, 01:24 PM
Rounders's Avatar
Rounders
Rounders is offline
Originally Posted by LQQK_OUT
Check.
It's around 20 volts AC per 1k rpm. So as I said if he revs it up, will be around 80 volts.
4x20 is 80.
6-23???? If you want to insult me,get your crap together
What is the AC output of stator? That should go up to around 80 volts AC when revved up. Dc also involves volt regs, which converts AC to DC. I had bad plug limit it to 10 volts.
Quick Reply: stator 'half-dead'?
