Grinding/ clacking noise when hitting the starter.
Old 09-01-2024, 05:05 AM
KentuckyChristian's Avatar
KentuckyChristian
KentuckyChristian is offline
Default Grinding/ clacking noise when hitting the starter.
95 Dyna. Bought used with 5,000 miles on it. Only 7,400 miles on the mill now.
It's only happened twice, with a warm engine.
But I hit the starter button and get a grinding or clacking type noise. Hit the starter button again, she fires right up.
Anyone know what might cause this ?
Old 09-01-2024, 06:15 AM
Bubba Zanetti's Avatar
Bubba Zanetti
Bubba Zanetti is offline
Received 14,295 Likes on 6,112 Posts
I’ve got a 95 Dyna and mine has done it a couple times too.
I also had an 09 Road King that did it and it turned out to be the compensator was shot.
KentuckyChristian (09-01-2024)
Old 09-01-2024, 09:13 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Dan89FLSTC is offline
Received 9,391 Likes on 5,000 Posts
Originally Posted by Bubba Zanetti
b
The OP`s compensator is completely different from an `09.
@KentuckyChristian The description makes me suspect the starter clutch is on its way out.
Make sure the battery and charging system are in good working condition.
The following 9 users liked this post by Dan89FLSTC:
98hotrodfatboy (09-01-2024), Addicted to Chaos (09-01-2024), KentuckyChristian (09-01-2024), Max Headflow (09-02-2024), pgreer (09-01-2024), s-glide76 (09-01-2024), tar_snake (09-02-2024), Tommy C (09-01-2024), Yankee Dog (09-01-2024) and 4 others liked this post. (Show less...)
Old 09-01-2024, 11:18 AM
KentuckyChristian
I figured it was something in the starter.
Battery and charging system are good ( so far). Looks like I'll be putting a starter motor on this winter.
Old 09-01-2024, 11:50 AM
Rounders's Avatar
Rounders
Rounders is offline
Received 2,240 Likes on 1,774 Posts
A weak battery can reveal a bad starter clutch.
Any work done to engine, like raising compression?
Old 09-01-2024, 01:10 PM
98hotrodfatboy's Avatar
98hotrodfatboy
98hotrodfatboy is offline
Received 5,408 Likes on 3,616 Posts
Are there any mods to the motor?
Old 09-01-2024, 02:09 PM
Dan89FLSTC's Avatar
Dan89FLSTC
You don`t need to replace the starter motor, just replace the starter drive clutch.
Item 21 in the illustration, still available from the dealer.
You can get them from the aftermarket, but all you will get is the clutch unit (item 37), nothing else.
illustration
KentuckyChristian (09-02-2024)
Old 09-02-2024, 06:45 AM
KentuckyChristian
Battery and charging system are good.
No mods to engine other than exhaust and air cleaner / breather.
Idle mixture jet has been uncapped and dialed in.
Old 09-02-2024, 06:49 AM
KentuckyChristian
Old 09-02-2024, 05:39 PM
Rokinrider's Avatar
Rokinrider
Rokinrider is offline
Connection to the primary helped my 97 Dyna. I’m not sure if I will rebuild it or replace it this winter. Only 20,000 on it. But the age is probably the culprit.
Quick Reply: Grinding/ clacking noise when hitting the starter.
