Stroke or not stroke, that is the question.
Hello all, I’m putting together a rider Shovelhead, nothing crazy but will be ridden fairly hard. I want to build a solid engine . I have the opportunity to get a 4-1/2 stroke s&s crank, I don’t want to bore the cases to 3-5/8 so I will be running 80” barrels. I’m debating between the 4-1/2 stroker or a 80” crank. Would love to hear from people with real life experience with these engine combo’s. What are your thoughts? Thanks
Personally I love being stroked....but maybe this isn't the forum for that revelation....
With stroked motors comes higher piston speed, with higher piston speed comes higher wear but to some the price is worth it for the great gobs of torque it delivers.
I had a C3 Corvette, stroked to 6.2 litre and it was like the Starship Enterprise, you mashed the throttle, and everything went blurry until you arrived somewhere else in the universe...I've ridden stroked Evos that feel pretty much the same.
I put the 4-1/2" S&S Stroker kit in my 1976 FXE back in the early 1980's. It made plenty of power but to be honest if I didn't stroke it and all the other mods, I would probably still have that bike. I had .040" or .050" oversize pistons in the standard (but bored out) 74" cylinders. I put more miles on that bike than all my other Harleys combined. I blew the transmission all across the highway back in 91 and it also took out the engine in the process. I had 2 plugs per cylinder and head work by Lakeshore HD in Chicago, Andrews "B" grind, and S&S Super "B" back then. It would run, but in the long run it was more of a pain in the butt; it would have lasted longer as stock. Young, dumb, full of you know what!
The following 3 users liked this post by sbrmike:
The following 4 users liked this post by johnjzjz:
AJSHOVEL (08-30-2024),
Max Headflow (08-29-2024),
Spanners39 (08-29-2024),
Ytcoinshooter (09-03-2024)
The following 2 users liked this post by Spanners39:
Racepres (08-30-2024)
Joe12RK (08-30-2024)
My First impression is...What Exactly do you expect to Gain...especially with a Shovelhead.. No Matter what Anyone Says..Money spent on Performance for a Shovelhead, is Much better spent on an Evo..best Cost/Reward ratio out there...Still. Back in the '80's...yea..Not many Options for Performance, except to get a Sportster.. Flame On!!!!
Received 49,780 Likes
... and there weren't kits ( a combination of parts in a package ) back then ... Dyno's weren't everywhere so seat of the pants was a factor then out to the track ... You bought what your group had tired in many cases ... S&S , Delkron, STD, Truett Osborne ... True enough there is better bang for your buck doing an EVO ... but an EVO ain't a Shovel
I enjoy My Shovelhead for What it Is!!
Fritz Franz (09-02-2024)
