Great Chain
Great Chain
I put on a real US made Diamond rear chain earlier this year. The previous chain that I had put on (with new sprockets) was a terrible chain. It needed major adjustment after each ride. It was NOS Harley but I think an employee swapped the Harley chain out of the box and put a cheap, no name, unmarked chain, new in the wrap, in the box. Around the time I bought it they had recently fired an employee from a posting on Facebook where a fellow posted about how many great deals, well below list, that he was getting from his friend at that shop. He was selling to friends, pocketing the money, and not ringing it through the cash register.
Well anyway, I got 6,548 miles out of that chain. I probably should have changed it months ago, but ran it as long as I dared. I don't remember how many links I cut out of that chain during it's life, but as I said it would be very loose after every ride.
This new chain has 684 miles on it. I did not change sprockets as they looked good. I generally change two chains to one set of sprockets unless they show the wear. I will also add that I lubed the chain with the white Belray chain lube (not wax). Today I took a 50 mile ride and decided to do some maintenance on the chain. I cleaned it off with my 3 way brush, lubed it very well with Belray, found the tight spot, lowered the bike, sat on it, and used my 90 degree bend long handled pipe and to my surprise, it was perfect! It looked like I just put it on!
The following 4 users liked this post by sbrmike:
The following 3 users liked this post by PeterB:
The following 2 users liked this post by Max Headflow:
Racepres (08-30-2024),
Ytcoinshooter (09-10-2024)
SbrMike;
Thanks for the review and great chain post. Just how much would it cost a fellow to see a picture of that right angle long handled pipe home made measurement tool you are using?
Some of us are new to us shovelhead riders and reinventing the wheel takes time.
Tried and true tips worth their weight in gold.
SbrMike;
It is not much to see. It is a piece of 1/2" hard copper pipe (tubing) 3 feet long with a 90 degree elbow on the end with a 3 inch piece of 1/2" hard copper pipe in the elbow. You could make one from 1/2" PVC pipe for next to nothing. I just had that piece of pipe lying around as is from a plumbing project.
