Notices
Can I remove this bolt?
Old 08-23-2024, 10:24 AM
steelpony16's Avatar
steelpony16
steelpony16 is offline
Default Can I remove this bolt?
Hey All,
In the state of PA they can no longer put inspection stickers on the plate shown in the attached picture.
So my new sticker is on the forks. I'd like to remove the plate but don't know if it's okay to remove that bolt that's holding it in place.
The bike is sitting on the kickstand. Is that bolt holding 2 parts of the motorcycle together, If I remove it can they become misaligned?
I will put the bolt back in once the plate is removed.....
TIA
Old 08-23-2024, 11:21 AM
Torkmizer's Avatar
Torkmizer
Torkmizer is offline
It's like a mattress tag man, you gotta leave that ugly pos on your bike until the day it finds it's way to the scrap heap or face penalty of fine or imprisonment
The following 3 users liked this post by Torkmizer:
DeeRoe (08-23-2024), hdbob2006 (08-30-2024), Rogue1 (08-25-2024)
Old 08-23-2024, 12:12 PM
GalvTexGuy's Avatar
GalvTexGuy
GalvTexGuy is offline
Received 4,182 Likes on 2,297 Posts
Is that bolt for the passenger footboard bracket? It looks like it is, but I can tell you that’s not the original bolt. It should be a 5/16-18 x 1 hex socket head shoulder bolt, part #4916.
Old 08-23-2024, 12:46 PM
steelpony16
It is not for the passenger footboard bracket.
Old 08-23-2024, 01:03 PM
GalvTexGuy's Avatar
GalvTexGuy
In that case that fastener is for the BRACKET,RR ENG MNT | rear fork (left) and the OEM part number is a 3057 (7/16-14 x 1-1/4 hex head w/washer w/lock patch). That fastener on your bike may not be the OEM fastener.
I can’t tell you if it’s safe to remove it or not.
Old 08-23-2024, 01:06 PM
GalvTexGuy's Avatar
GalvTexGuy
Old 08-23-2024, 01:08 PM
steelpony16
In that case that fastener is for the BRACKET,RR ENG MNT | rear fork (left) and the OEM part number is a 3057 (7/16-14 x 1-1/4 hex head w/washer w/lock patch). That fastener on your bike is not the OEM fastener.
Thank you Sir, appreciate the effort.
Old 08-23-2024, 01:18 PM
steelpony16
I was looking at that on the Harley Website, you are correct, Item No. 1......
Anyone know if I can remove that bolt without screwing anything up?
Old 08-23-2024, 01:30 PM
Pappy35's Avatar
Pappy35
Pappy35 is online now
I GOT IT!!! Remove the screw, ditch the tag, reinstall the screw. BadaBing, easy...peasy...the great "can I remove this" mystery of Aug. '24 is solved! ​​​​​​
The following 4 users liked this post by Pappy35:
Addicted to Chaos (08-23-2024), BrandonSmith (08-23-2024), DeeRoe (08-23-2024), Goose_NC (08-23-2024)
Old 08-23-2024, 01:55 PM
ahhlou's Avatar
ahhlou
ahhlou is offline
I took a look at the service manual. In my case the 2011 Touring Service Manual, Chassis chapter, rear fork section. I see no reason why you can not remove the screw (fork bracket screw) to delete the tag.
It indicates 2 drops of blue Loctite before installing it.
2.21 REAR FORK, Installation/Apply two drops of
Loctite Medium Strength Threadlocker 243 (blue)
to threads 55-65 ft-lbs
steelpony16 (08-23-2024)
Quick Reply: Can I remove this bolt?
