Cam comparison question for Evo motor
Old 08-20-2024, 12:21 AM
Adam76's Avatar
Adam76
Adam76 is offline
Default Cam comparison question for Evo motor
Hi guys,
just have a question about possibly changing out the bolt in EV13 cam in a '98 Road King.
The plan was to install Wiseco 10-1 compression pistons, cc the heads and a bigger cam.
WilI I gain much?
Which cam would suit the higher compression??
(I'm doing a top end rebuild anyway, hence my question).
Thanks.
Old 08-20-2024, 02:36 AM
PeterB's Avatar
PeterB
PeterB is offline
Depends on what sort of performance you want the cam to give you. I fitted an Andrews EV13 to my 95 RK (stock compression) and am very happy with it. Gives lots of extra low and midrange power for two-up riding on steep twisty roads. Others prefer the EV27 that gives more top end power. I think bumping the compression up would get the best out of the cam but I just can't be azzed tearing the top end apart.
Old 08-20-2024, 02:40 AM
98hotrodfatboy's Avatar
98hotrodfatboy
98hotrodfatboy is offline
Received 5,403 Likes on 3,613 Posts
Best combination I ever saw was a 10.2:1 comp with stage II heads ( 1.90/1.61 valves and 83 cc chambers) with a Woods W6 cam.. High 80's Torque and HP.. Roughly a 20% gain over stock if not more.. if you get the heads done properly with .600" capable valve springs the cam choices are unlimited and with the right compression will put you into the 90's tq/HP...
Keep in mind you have a heavy bike so most will tend to build around torque not HP...
Paintslinger16 (08-20-2024)
Old 08-20-2024, 03:01 AM
Adam76's Avatar
Adam76
Adam76 is offline
Thanks 98hotrod.
I don't have a machine shop here that can do what you've suggested with the heads, but I can get a valve job and cc'd to 83cc.
10.2 comp should be easy to achieve, so the Woods W6 cams could be a good option.
The other cam that might work at that compression is the Vthunder 3020 ?? It has similar specs the the W6....
Old 08-20-2024, 05:24 AM
eighteight's Avatar
eighteight
eighteight is online now
Received 4,951 Likes on 2,851 Posts
Old 08-20-2024, 05:42 AM
Adam76's Avatar
Adam76
Adam76 is offline
Hey eighteight, are you recommending the ev46 cam?
I'm guessing this cam would probably benefit from the extra compression of the Wiseco 10-1 pistons.
Old 08-20-2024, 06:09 AM
eighteight's Avatar
eighteight
Just a reference point for what is basically a bone stock EVO
Old 08-20-2024, 06:28 AM
pgreer's Avatar
pgreer
pgreer is offline
Received 1,605 Likes on 1,033 Posts
I didn't see where you mentioned your riding style. The cam you currently have provides good torque (which is more important than HP) from idle to around 4000-4500 rpms (where it start tapering off) or so depending on other components, which is good for acceleration from stops or riding two up or packed with gear. But with early closing intake valves (31 degrees) you don't want too much more compression because cylinder pressure will be increased. I'd also check the cylinder bases to be sure they are flat and then set the squish band when assembling the top end by using the proper base and head gaskets.
The 3020 has a later intake closing (42) and more duration and will provide more mid and top end power, but you will lose some bottom end torque. So it better suited for a lighter bike. Going to 10:1 compression will help the low end torque some, which you need with a heavy bike like a Road King. So you can gain some additional torque back by bumping the compresion a little, but depending on where you live I'd be cautious of exceeding about 9.2-9.5:1 unless you have regular access to 93 or better octane gas and the ambient temperature doesn't regularly exceed 90 degrees.
Basically, to get more power in the mid and higher RPM's, you will lose some low end power. You are riding torque, not HP. So go with a combination that best suites your riding style.
Paul
98hotrodfatboy (08-20-2024)
Old 08-20-2024, 06:36 AM
eighteight's Avatar
eighteight
Originally Posted by pgreer
I didn't see where you mentioned your riding style. The cam you currently have provides good torque (which is more important than HP) from idle to around 4000-4500 rpms (where it start tapering off) or so depending on other components, which is good for acceleration from stops or riding two up or packed with gear. Paul
^ Agree , as I used the EV 13 years ago in an FXRT with tall gearing ( 34T front)
Old 08-20-2024, 06:37 AM
Adam76's Avatar
Adam76
Adam76 is offline
OK, sure. But how does that fit with my plan to use the 10-1 compression pistons? Just a bit confused as to what you're suggesting.
Thanks
Quick Reply: Cam comparison question for Evo motor
