Broken Exhaust
Old 08-19-2024, 03:11 PM
johnod's Avatar
johnod
johnod is offline
Default Broken Exhaust
97 FLHTCUI
My rear exhaust header, has cracked completely in 2 where it exits the rear head and forms a Y to go left and right.
I doubt a repair would be a long term fix.
The part number is 65626-95,
I read somewhere that earlier and later model header pipes will fit.
Anyone know anything about that, or what will and won't fit?
Thanks for any help.
I don't want an entire 2 into 2 system especially at the moment.
Old 08-19-2024, 03:43 PM
Schex's Avatar
Schex
Schex is offline
Received 7,035 Likes on 1,853 Posts
Up to ‘08 touring will fit, ‘07 & ‘08 will have O2 sensor bungs that would need block off plugs.
The later pipes are better in the y area.
The following 6 users liked this post by Schex:
chrisflhtc (08-20-2024), Max Headflow (08-19-2024), Mountainkowboy (09-01-2024), pgreer (08-19-2024), Racepres (08-19-2024), Uncle Larry (08-19-2024) and 1 others liked this post. (Show less...)
Old 08-19-2024, 04:22 PM
Racepres's Avatar
Racepres
Racepres is offline
Received 2,320 Likes on 1,672 Posts
If Bone Stock Mounting, i would think this is an unusual Failure...If, However, someone mounted to the Chassis...Breakage is about Guaranteed..
Old 08-19-2024, 05:46 PM
im's Avatar
im
im is offline
I guess it depends on your needs and pocket.
You can convert to true dual for about $200.
Basically replace the back exhaust 'Y" split with the curved piece in kit and use the included straight pipe for right side.
https://fullsac.com/product/true-dua...8-flh-touring/
Old 08-19-2024, 06:04 PM
johnod's Avatar
johnod
johnod is offline
I was looking at that.
Have you used it?
How is it?
Old 08-20-2024, 12:09 AM
Dano523's Avatar
Dano523
Dano523 is offline
Photo would help, since need to know if just vibration crack out, or pipe rusted/rotted out from the inside out, and tig welding it with SS fill rod (Heat flue remover on the chrome to get it back to gleaming) is no longer an option without internal sleeve'g for structural suport and maybe gusset add.
Note, back in days of golfsmith, they sold a liquid that would shine chrome back to silver, when heat would cause the chrome to turn blue from torching to pull golf club heads off the shafts, and not hard to polish up SS filler weld to get very close to polish chrome color as well.
I bring his up, since you may not tig weld, but may be a shop around that could tig up the piece for around $100, and would be a lot cheaper than having to replace the entire exhaust system. Hell, if not worried about perfect looking welds out the gate (or cover is going to hide where the weld is going to be), then could FCAW the broken pipe back up with Blue demon 308L SS flux core wire, and just have a more final clean up on the welds if not going to be covered.
Hence most of the time, the pipe will want to break down at the lower section if pipe does not have the extra gusset there, and pipe cover is going to cover up the weld repair, so the Blue demon 308L SS flux core wire works there really well, since its not going to rust after a while like standard NR-212 multi pass wire instead.
Note, FCAW welder has to be DC (note A/C), and unlike single pass or NR-212 multi pass wire where you run electrode DCEN negative and ground strap as postie to put more heat into the work piece, need to swap out leads to DCEP and ground strap as negative. The reason for this, you want to put more heat into the wire, than the work piece with the SS flux core wire.
Amazon Amazon
Old 08-20-2024, 05:26 PM
johnod's Avatar
johnod
johnod is offline
https://www.amazon.com/Blue-Demon-30...00G5GHA7E?th=1
https://youtu.be/yx6weJurINc
Thanks, I've decided to go this route.
I could have it welded but have no faith in it being a good long term fix.
flhchaz (08-21-2024)
Old 08-21-2024, 04:14 AM
Bigwillie's Avatar
Bigwillie
Bigwillie is offline
that happened to my 2007 electraglide. the bracket from heat shield to starter was cracked and the vibration eventually cracked the exhaust. harley old. stock had it.it was $500 bucks
Old 08-29-2024, 01:39 PM
johnod's Avatar
johnod
johnod is offline
In case anyone is interested i went with the Fullsac kit.
It fit well and seems to be doing the job just fine.
Thanks for all the help and suggestions.
The following 5 users liked this post by johnod:
flhchaz (08-29-2024), im (08-29-2024), Max Headflow (08-29-2024), Racepres (08-30-2024), Schex (08-29-2024)
Magnut1
08-29-2018 08:12 PM
BoneDigger
Exhaust System Topics
12-21-2014 07:49 AM
elcactus
12-29-2008 08:24 AM
martinez_nc
01-26-2008 06:14 PM
martinez_nc
01-26-2008 01:05 PM
Quick Reply: Broken Exhaust
