Engine Oil spout question FXDF
So I've been racking my brain lately trying to fix what I find to be a completely stupid issue with the Fat Bob or most Dynas in general. The Oil fill spout location being right below the crank.
Most Exhausts make checking the oil a pain since the fill spout is right in the path of the exhaust, and ya i could change the ehxaust, but i notice the later model engines moved the spout somewhere else.
Is there an alternative on the early Dynas? 2008 and up? I have an exhaust I really like, dragstyle and it's right in the way of the spout, and taking the exhaust off everytime I want to check the oil is not an option. Is there special dipsticks or spouts I can't seem to find since Google is becoming a pain in the ***? Or a way to relocate it somewhere like near the tranny dipstick?
Or is this one of Harleys blunders and im kinda screwed with no options?
Top Answer
08-08-2024, 06:22 AM
Received 21,697 Likes
Putting on aftermarket parts/exhaust there is always a risk of fitment.
It is up to the individual to do due diligence when modifying their motorcycle and find parts that fit correctly and be able to access maintenance parts.
The "blunder" is with the engineers that designed the aftermarket part, not Harley Davidson.
Looking at your photo it seems if you had a filler plug with a really low profile top it would be possible to remove with a bit of wiggling, and you could use a funnel with a piece of hose attached to refill oil. I don't know if such a low profile cap is available for purchase, maybe you could have one made by a machine shop. An aluminium plug with two grooves for o rings and a 1/8" knurled top would be an easy job for someone with a lathe.
Your other option is to try to find the same kind of exhaust but made for 06+ Dynas. For instance the V&H big shots come in two different versions with a slightly different routing of the rear pipe at the transmission.
MacSteve (08-07-2024)
Looking at the photo you have a 2006 or newer Dyna. It is usually the other way around, a lot of exhausts do not fit 2005 or older Dynas due to the oil filler location on those bikes.
And nearly every pipe I see for this model year aside from a few really restrict access. Kind of a lame design in my opinion for customizing since I do like the short pipe styling.
Ya, it originally had vance and hines on it. Could barely get the cap off to check the oil, this set of pipes I was told fits. After I got it manufacturer said if I wanted to change the oil id have to loosen the pipes to do it. I was pissed.
Telling a customer to remove the exhaust to check the oil is about the stupidest thing I have heard today.
If you like the short drag pipe look I think there are pipes from V&H, Cobra and Freedom Performance to name a few that are made for 2006+ Dynas, and that will allow full access to the filler.
even with my V&H 2-1 big radius blocked the dipstick, I could only get it out if I marked the cap so I knew when the threads were clear inside the spout to I could pull it put and force it past the exhaust. 2008 dyans and above got ABSOLUTLEY F*CKED, and all the manufacturers don't care. V&H included.
More common than you'd think. If you're not a fan of the classic style pipes and actually want an individual look that is answer you get most of the time. Which removing an exhaust to do oil changes is annoying but, completely unable to check it?
I am running a S&S exhaust made for newer Dynas on my bike, it almost covers the oil cap but I can get it out with some wiggling. The cap on 05 and older bikes is not threaded, it's just a plug with o rings that you pull straight out.
I need to use a hose to refill oil but I think that's okay, I don't do that very often.
The following 10 users liked this post by CoolBreeze3646:
Addicted to Chaos (08-08-2024),
Buelligan666 (08-08-2024),
Chicago Ken (08-08-2024),
hattitude (08-10-2024),
Jackie Paper (08-08-2024),
and 5 others liked this post.
The following 2 users liked this post by misfitJason:
MacSteve (08-08-2024),
snake_eyes (08-12-2024)
mines an 08, and it originally had V&H big radius 2-1, and like i mentioned above i had to mark my cap so i knew exactly where the threads had the least activation so I could force it past the pipe.
