2018+ Softail Models Breakout
FXLRS dash rattle
Old 08-06-2024, 10:02 AM
Mr.Rabies's Avatar
Mr.Rabies
Mr.Rabies is offline
Default FXLRS dash rattle
I will try to make this a short easy read.
2021 lowrider s with 900 miles has a terrible rattle on the dash under a certain RPM before shifting between 1-2-3.
i have tightened the dash bib. even removed it to check the gauges tightness in the bib.
check the tank bolts. its like the dash bib is rattling but its tight.
my question is anyone with a lowrider s have dash rattle as a common issue? if so id like to know the census.
its not wheel bearing/wheel,neck related. its like a plastic thing bolted on somewhere.
rather annoying.
Old 08-06-2024, 10:03 AM
Phil McGrath's Avatar
Phil McGrath
Phil McGrath is offline
Hmmm, is the gasket there or pinched? Check and see if the bracket is intact and make sure the clips are secure there isn’t a whole lot to wiggle and jiggle underneath….
Old 08-06-2024, 10:14 AM
Kadab's Avatar
Kadab
Kadab is offline
rather annoying.
Mine had a fuel cap and clutch lever that rattled. Have you checked those?
Mr.Rabies (08-07-2024)
Old 08-06-2024, 10:57 AM
Durham man's Avatar
Durham man
Durham man is offline
Received 1,623 Likes on 1,016 Posts
Tank bolt?
Old 08-06-2024, 11:04 AM
evildiesel's Avatar
evildiesel
evildiesel is online now
I bet its the gas cap, stock ones are annoying
The following 2 users liked this post by evildiesel:
Phil McGrath (08-06-2024), Uncle G. (08-07-2024)
Old 08-06-2024, 11:30 AM
NZLowrider's Avatar
NZLowrider
NZLowrider is offline
The chrome headlight retaining ring was vibrating causing an annoying noise on mine
Old 08-06-2024, 11:45 PM
Gimlet's Avatar
Gimlet
Gimlet is offline
Received 2,703 Likes on 883 Posts
Yep. I didn't realise mine was doing it until I forgot my ear plugs one day. It wasn't so much a rattle as a buzz that kicked in at a certain frequency, usually in the lower gears at higher revs when you're not going fast enough for the wind noise to drown it out. I was grabbing levers, clocks, fairing etc trying to find it when my arm landed on the fuel cap and it stopped.
I cured the problem by not forgetting my ear plugs again. A louder exhaust works too.
Old 08-07-2024, 08:57 AM
Mr.Rabies's Avatar
Mr.Rabies
these did rattle, however fixed now i still have the dash bib issue. with 900 miles on the bike you think it will show its face soon.
snugged all bolt the tank bolts also.
im going to remove it and the guages and go for a ride later today to see if its the culprit.
Old 08-07-2024, 11:14 PM
Toolmaker5150's Avatar
Toolmaker5150
Toolmaker5150 is offline
I had a rattle in the same rpm-shifting scenario you mention. It turned out to be a loose
baffle in my exhaust.
Old 08-13-2024, 09:42 PM
Mr.Rabies's Avatar
Mr.Rabies
Turns it irs the bib/gauges.
removed, no rattle. Installed back on, rattles again.
bolts are right. Perhaps try silicone under it?
The following 2 users liked this post by Mr.Rabies:
luckiestiff (08-14-2024), Phil McGrath (08-13-2024)
user 7298720
Pan America
08-10-2022 04:52 PM
SparkyD
Shovelhead
05-10-2021 02:42 PM
Harleyrookie
Electrical/Lighting/Alarm
11-04-2019 03:24 AM
cherrick
09-17-2011 08:24 AM
electra glide
11-22-2009 10:06 AM
Quick Reply: FXLRS dash rattle
