First time posting, but I have an issue on my 2016 Ultra. I recently changed out the failed factory LED passing lights with new Eagle Lights gen III units. After installing went to check and one of them is much dimmer than the other one. Swapped sides to rule out light and there was no difference. That one side remained much dimmer than the other side. Voltage on both sides are the same. Checked ground connections and even jumped out the ground and went straight to the frame. Still no change. Any help would be greatly appreciated.
@JBUltra65 I have moved this thread from the Welcome section to the Electrical / Lighting / Alarm section as you will get better responses to your question in this section.
John, I see 7 different ULTRA models in the fish. Why I ask newmembers to add a signature line.
My guess is the issue is the pins in the plug on the bike harness.
PS, since your thread was moved, if you plan on enjoying your ride here on the HDFORUM, make another new thread over in the newmember welcome area to say hello.
