Bike won't start - turns over but won't idle and backfires
Hello,
I installed a Tmax ECM about 7 years ago and it has worked great. However, today I tried to start my bike (2006 Nightrain) and it would not start. I initialized the ECM just in case that was the issue (actually did this 2-3 times). After multiple initializations and attempts to start, it backfired last attempt. I rode it a few days ago and it backfired slightly a couple of times (never did this before) when I gave it some throttle after a stoplight. I changed the sparkplugs a few days ago (gapped at .40) as the front plug was quite dirty / black so I figured the bike was misfiring due to a bad plug. Now the bike won't run (I doubt this has anything to do with the new plugs even though this was first ride I planned after installing them). I have a suspicious feeling, due to the backfiring and slight smell of fuel when I try to start the bike, that I may have one or both fuel injectors failing (I have the 25 degree injectors and they were likely installed with the Stage 1 upgrade before I bought the bike). I ran the diagnostics today and no codes show up!
A couple of questions:
- If this were an ECM issue would that show up as a trouble code?
- Do you know if a bad fuel injector would throw a code?
- Short of hauing the bike to my indy shop, any ideas on how to further troubleshoot?
Brookiez28 (07-30-2024)
check fuel pressure, and tps for proper idle voltage and throttle opening setting, and check for vacuum leak. Also check your compression.
Brookiez28 (07-31-2024)
