Shocks Upside Down
My 2001 Road King has HD Part number 54000114 Premium Adjustable Touring shocks (not air shocks) on it, a previous owner has put them on it.
I noticed they are mounted upside down I believe. The piston part of the shock is on top on both sides, and the shock with the adjustment **** is installed on the right brake side.
From what I've been reading it doesn't matter on these models, and others have them mounted upside down as well. Should I just leave it?
Thanks guys.
Thanks guys.
bulldog1776 (07-14-2024)
The following 2 users liked this post by Bass Player:
bulldog1776 (07-14-2024),
sanman4ever (07-14-2024)
Progressive recommends mounting the shocks upside down with the adjustment at the bottom so they could be adjusted without removing saddlebags.
yes, that is correct. however, they did not recommend putting the left shock on the right and vice versa. they also do not recommend, at all, putting the premium hand adjustable shocks on a bike of that age. that is the older swingarm that has not been beefed up. the premium shocks are basically a mono shock, the right shock does almost nothing. so all the strain is placed on the left side of the swingarm. that can cause some flex, and introduce wobble. are there people doing it and not experiencing that? sure. are there people who are experiencing that? also probably true. i wouldn't chance it. they aren't that good anyway. get some proper shocks that equalize the load across both sides of the swingarm. just my $.02.
The following 3 users liked this post by skratch:
"Progressive recommends mounting the shocks upside down with the adjustment at the bottom so they could be adjusted without removing saddlebags." Post 5
This may be the reason.
"Progressive Suspension's 944 Ultra Low Shocks upside down as per their addendum instructions" Post 2
But no reason is stated in the addendum.
My two-cent comment:
In the 1970s decade, we motocrossers mounted rear shocks upside down for performance.
But.... I don't remember why![Smile](https://www.hdforums.com/forum/images/smilies/smile.gif)
