ECM:s and Soft Ware Levels
Hello,
I have a Dyna 2006 with the ECM 14 and a tune with software level 179 (for 2007-11) at the present moment.
My question is: Has anyone here a Harley with the ECM 14 and a tune with software level 357 in it?
That would be that you have an older bike like 2006-2007 and have flashed your ECM with a tune for the 2012-2015 Harleys.
Thanks a lot in advance and Best Regards
The following 2 users liked this post by rigidthumper:
Lonewolf176 (07-12-2024),
OakMountainRider (07-12-2024)
The reason I ask is that I cannot find the Adaptive Control Switch in my 176 tune, whereas this switch is present in a 357 tune.
I wonder is there anyone here who has a Harley, 2011 or older with 176 software level and Target Tune with Adaptive Fuel Control working? Can they see this switch in their WinPV, and can they see AFF activity in their PV?
Thanks a lot
My bike is the international version. And I have installed broadband O2-sensors. I have used Autotune Pro for several years, recently I upgraded to Target Tune. The Closed Loop short term trims work fine, but I have yet not been able to activate the Adaptive Fuel Control.
This is why I wonder if anyone with a Harley -2011 and Target Tune has succeeded in that and knows that the Adaptive Feul Control is working.
The 357 tune is different though. There I can see both the temperatures and the switch. From that I conclude Adaptive Control is present in the 357 tune. And off course my thought then was to export all value files from my 176 tune, import them to the 357 tune and flash the ECM. (Perhaps not possible, though.)
Anyway, as Dynojet advertise Target Tune as handling Adaptive Fuel Control, and as the PV has Adaptive Fuel Factor as a datalog, and as Dynojet have been trying to help me get the AFF active through their support, I find it a bit unbelievable that the hole thing should be a gimmick and that Adaptive Fuel Control does not work with broadband sensors.
But you could be right and Dynojet is bluffing off course.
We live in strange world.
P. S. I want to add, that the broadband sensors are not connected to ECM, but to the Target Tune, which is connected to the ECM through the NB stock connectors.
Here is the thread where it was discussed. Start around post 160. https://www.hdforums.com/forum/the-d...t-tune-17.html
For all that want to know, There is NO adaptive learning when Wide Band sensors are used. I do not care who's unit you use as the ECM does not have the necessary code to support it, it's just that simple. There is integration but none of that is stored and reused. This is nothing new and it's been this way since HD started using the Delphi fuel injection. If Dynojet is trying to say there is, then they are not being truthful.
rigidthumper (07-12-2024)
Reading threads can put ants in the head and one may ask:
1/ Does my Harley have Adaptive Fuel Control at all?
2/ If it has, can Adaptive Fuel Control be activated properly through the tune? (Switch, temperature thresholds)
3/ Can the info that comes from Target Tune be similar to the NB sensors so that the trims will be stored in the ECM as was thought, improving the bikes performance?
Well, I hope soo. I cannot see why not.
Anyway, thanks for you input. The subject is interesting.
2006 US Domestic Dyna came with and without narrow band O2 sensors. 2006 Dyna did not have adaptive fuel. Adaptive fuel was turned on in 07 and later.
05A and later ECMs are O2 capable. 05A is actually an 06 ECM before the PN revved. These ECMs were capable of Wide Band sensors is using special engineering software, but in the wild they are all narrow band.
