Sifton Oil Pump Drive Gear Kit - 12-1505
Old 07-11-2024, 07:46 PM
NM Pan-shovel's Avatar
NM Pan-shovel
NM Pan-shovel is offline
Default Sifton Oil Pump Drive Gear Kit - 12-1505
Has anyone upgraded their early style OEM cast iron oil pump with this Sifton high-flow kit? Here's what Dennis Kirk says (or Sifton does) about this kit:
  • Sifton high flow pinion shaft oil pump drive gear for 1939-1953 Overhead Valve Big Twins.
  • 6 tooth gear increases oil flow rate by approximately 25%.
Just curious as even if bottom end checks out, I'll be pulling the timing cover and was considering doing this upgrade if worth it.
Thanks.
Old 07-12-2024, 02:15 PM
johnjzjz's Avatar
johnjzjz
johnjzjz is online now
Received 4,755 Likes on 2,988 Posts
I have never found that helped the early engines - they have just the right amount of oil volume and its 70 years old and did not disintegrate into a heap
but who am i to stop someone from over oiling and making it leak more. Then it ever has
Old 07-12-2024, 02:24 PM
NM Pan-shovel
Hah! Well, I wouldn't want more leaks, as this thing rarely leaves more than a drop from the scroll 'seal' on the crank, or from the crankcase vent.
Cool, thanks for weighing in, John. I'll leave the OEM pump alone, save for a new spring and ball while I'm futzing with the engine.
rroadking02@gmail.com
Knuckle Head
10-21-2018 12:34 PM
jsbridgew
Exhaust System Topics
08-08-2011 07:15 PM
jessebradley
Engine Mechanical Topics
12-04-2010 08:02 PM
ragrat64
10-19-2006 12:43 PM
Quick Reply: Sifton Oil Pump Drive Gear Kit - 12-1505
