2000 FXST - Gas Range
Old 07-11-2024, 03:15 PM
ThunderClap's Avatar
ThunderClap
ThunderClap is offline
Stage I
Default 2000 FXST - Gas Range
So I'm new to riding and have looked online for info on gas range for my 2000 FXST. From the forums, I realize that the gas gauge is just garbage and to go by the odometer or trip meter. Is there a good average or range to go by before I should be concerned about filling up? I'm going off the assumption it's a 3.5 gallon tank with 1.5 gallon reserve. I've been filling up around 80-100 miles which seems low and I'm only filling about 2 gallons when I do that. It seems pretty self-explanatory but I wondered what anyone else with more experience thinks.
Old 07-11-2024, 04:15 PM
back again's Avatar
back again
back again is online now
Received 5,765 Likes on 2,420 Posts
I gas up at 165 if I can push 180 if I’m not hauling ***. 05 Train
Stiggy (07-11-2024)
Old 07-11-2024, 04:19 PM
Stiggy's Avatar
Stiggy
Stiggy is online now
Received 5,760 Likes on 3,144 Posts
On my Dyna. look for fuel between 160 and 200. (The gauge is useless so I use the Trip Odometer only.)
back again (07-12-2024)
Old 07-11-2024, 11:10 PM
hattitude's Avatar
hattitude
hattitude is offline
Received 7,989 Likes on 4,293 Posts
I have a 2001 FXSTS. The bike is Stage I, and tuned the carb myself.
I average 40 mpg on that bike. That includes a bunch of 75mph freeway travel here in SoCal.
I don't push the tank to it's limit. I usually refuel around 120-130 miles. I have gone 160 miles, without needing to switch to reserve.
Obviously, YMMV.....
Old 07-12-2024, 09:32 AM
byersmtrco's Avatar
byersmtrco
byersmtrco is online now
My 03 Heritage (5 gal, like yours) I fuel around 140. My gauge is wrong as well.
When it's just above E, and the low fuel light is on, it will take 3.5 gal.
I also rely on the trip-meter.
Mileage is 35-40 depending if it's all back roads or freeway.
Old 07-12-2024, 10:41 AM
Buelligan666's Avatar
Buelligan666
Buelligan666 is offline
You have a petcock. It has a reserve position. Run it till it dies. Flip to reserve and ride it to the gas station. Seems pretty simple to me.
Cap77 (07-12-2024)
Old 07-12-2024, 12:09 PM
s-glide76's Avatar
s-glide76
s-glide76 is online now
Received 1,030 Likes on 423 Posts
Take miles ridden divided by gallons added to get your miles per gallon. Now multiply it by the capacity of your tank. (5 gallons). That's how far you can go before walking.
Of course you might get 48 mpg on a 55mph highway and only get 32 mpg doing 80 mph on the freeway fighting a headwind so you must consider that.
Me, I just shoot for fueling every 150 miles.
Old 07-12-2024, 01:10 PM
Cap77's Avatar
Cap77
Cap77 is offline
Received 5,744 Likes on 2,476 Posts
That was my SOP in the olden days.
fuel injection now...no reserve tank, or I'd still be doing it that way
suggestion to the OP
Start tracking your mileage so you know your bike's MPG for your riding styles
it's easy to do if your trip meter works
Pull up to same pump, in same position in relation to pump and fill to same level every time
after 3-4 tank's full, you'll have a very good indicator of how many miles you can roll without concern
You'll also know if your gas gauge is accurate (mine is) but i still go by my trip meter
..L.T.A.
Old 07-12-2024, 01:14 PM
2goldens's Avatar
2goldens
2goldens is offline
I'm pretty much in this range with my 2002 Fat Boy also. The heads have been reworked and gear drive cams added many years ago but no internals have been touched. Not sure how or if that affected fuel mileage.
I can probably get to the edge of 200 riding sensibly. But the 160 neighborhood is when I really start thinking I'd better gas up.
The fuel gauge gave up many years ago. There's been a repaint with brand new tank since then and the tank has flush mount caps on each side. The gauge was done away with.
Old 07-12-2024, 04:14 PM
touchdown's Avatar
touchdown
touchdown is offline
Received 1,745 Likes on 987 Posts
I think maybe he should go back to school and learn math. Lets see 100 miles and two gallons of gas. Hell he should be able to go another 500 miles.
Quick Reply: 2000 FXST - Gas Range
