fx 1978 rear rotor center in galiper
07-09-2024, 09:56 AM
Hi on a stock 1978 is the rear rotor center in the galiper ?
mine is offset
thanks
07-09-2024, 10:19 AM
Wheel spacers are Not exactly one size fits all..I always space the wheel for sprocket, and then Caliper.. caliper at the Caliper mount!!
07-09-2024, 11:33 AM
On my 1978FXE, the caliper is in the same position as the one in your picture.
07-09-2024, 08:46 PM
14GuineaPig
your rotor is more in the center of galiper then mine i like that better
07-09-2024, 09:52 PM
The first gen calipers are just disc brakes , that’s about all one can say
07-09-2024, 11:28 PM
A single piston caliper is often a bit offset as the fixed pad doesn't move.
07-10-2024, 07:54 AM
Quote:
Originally Posted by
Spanners39
Excellent Point that!! On that type brake caliper...tho on Floating pin mounts..centered is Good!
07-11-2024, 10:08 AM
I think it might just look like that due to the angle that the picture was taken. It looks like the right side edge of the rotor is in line with the line of the caliper where the 2 halves bolt together.
07-12-2024, 12:27 AM
Looks like the wrong spacer, too long.
number633
Wheels/Tires
01-03-2024 09:17 PM
PaulG75
03-31-2021 01:37 PM
cvaria
09-18-2016 03:06 PM
d-streetglidr
03-03-2013 02:00 PM
Charlie Greg
Wheels/Tires
08-09-2011 07:07 AM
