chirping noise
Old 07-08-2024, 04:18 PM
MAURICEM's Avatar
MAURICEM
MAURICEM is offline
Stage I
Default chirping noise
My 2011 street bob just started to make this chirping noise
any ideas what's causing this?
File Type: mov
Old 07-08-2024, 04:52 PM
Spartanden's Avatar
Spartanden
Spartanden is offline
Received 8,298 Likes on 6,041 Posts
I tell a lot of new comers to the forum to get: Factory Service manual and the Parts manual. Take to an office supply store and have them put a spiral binder in place of the glued binder. That will let the manuals lay flat on your bench. Get a three ring binder and record all your maintenance, repairs, accessories, etc. This will be a great reminder of what was done when. And great material to pass along to the new owner should you sell and upgrade. Also know how large your fuel tank is, a rough idea of your range per tank, and record your fuel usage. I have an app called Simply Auto that I record all my fuel used. I use the odometer and use the fuel gage as reference only. I reset the odometer to zero on fill ups, and I know I can safely get 200 miles on a tank on around town riding, and upwards of 230+ on trips.
Old 07-08-2024, 05:04 PM
squirrelsnest's Avatar
squirrelsnest
squirrelsnest is online now
Received 5,673 Likes on 2,824 Posts
Welcome to the forum from Virginia.................
Old 07-08-2024, 06:34 PM
Jackie Paper's Avatar
Jackie Paper
Jackie Paper is offline
Received 5,028 Likes on 4,215 Posts
Welcome Maurace to the HDFORUM.
I hope you continue to enjoy your ride here to.
Only as a suggestion, by me as a USER, create a signature line similar to my one line on my bike information.
The year, model, and all the letters Harley assigned to the bike. It will appear at the bottom of your post.
Doing this will be helpful if you ask a question. All Harleys aren't the same with many changes and variations over the year.
Of course, you can always add it to any thread with a question.
You can also add any other details you choose and a favorite picture to the signature lines.
If you like, you can also add a favorite picture for an Avatar you see at the top left of all your posts as a postal
PS…Questions would probably get more comments in the proper area using the dropdown menu under Forums in the menu above
It’s possible if a Community Team member sees your post, they may move it to a better area.
If they do, only as a suggestion by me, make another new thread back here in the welcome area to say hello and if desired introduce yourself
If you like, post question here as a new thread .
https://www.hdforums.com/forum/dyna-glide-models-9/
Old 07-08-2024, 07:00 PM
470004's Avatar
470004
470004 is offline
Received 16,343 Likes on 6,765 Posts
Welcome to the forum from New York.
Old 07-09-2024, 02:42 AM
imoo6170's Avatar
imoo6170
imoo6170 is online now
Welcome from Sydney Australia
Agree with Jackie Paper - best to raise your question in this section of the forumhttps://www.hdforums.com/forum/dyna-glide-models-9/ as you will get better technical responses than in Welcome Section (ie this section)
Old 07-09-2024, 04:38 AM
the wild hog's Avatar
the wild hog
the wild hog is offline
Received 2,961 Likes on 2,918 Posts
Welcome
Old 07-09-2024, 06:00 AM
TracerBullet's Avatar
TracerBullet
TracerBullet is offline
Received 5,298 Likes on 2,902 Posts
Welcome aboard
Old 07-09-2024, 06:13 AM
DeeRoe's Avatar
DeeRoe
DeeRoe is offline
Veteran: Marine CorpVeteran: Air Force
.....the chirping noise is probably all the people that will say, "This is a welcome area, and you'll have more luck getting an answer in the specific forum that relates to your question"
just sayin'......
Old 07-09-2024, 06:32 AM
Jackie Paper
What type of software opens that .mov file. My very new Galaxy S24 ULTRA doesn't know how to play it?
Quick Reply: chirping noise
