2005 Road King Coughing and Backfiring
Received 1,618 Likes
Cboy413 (07-02-2024)
P1353- Front cylinder combustion trouble.
1. Faulty Spark Plug: Inspect ignition coil and spark plug wire 2. Plug gap/Loose plug tip: Tighten the wires 3. Bad wiring on the injectors: Check and or Replace the injector 4. Faulty crank position sensor: Check and or Replace the crank sensor.
This is just a short list I pulled from another site, but it’s a start.
