Crane Fireball Cam
Old 06-28-2024, 05:33 PM
daven9113's Avatar
daven9113
daven9113 is offline
Default Crane Fireball Cam
Need a little help here. My current project is to put together budget Evo bottom end. Got the flywheels in the case (both '89), and oil pump ready to be installed. I would like to button up the bottom end, minus lifters. Cams are not cheap these days.
1) Got a good deal on an used, but useable FB 300-1 or FB 300-2 (hard to see if last number is 1 or 2). Anyway, so that's the first question? From Nightrider, Crane FB 300 is a drop in cam, so I know that should work fine. Is this a decent cam?
2) Cam gear has marking #7-0004B. Since being a "drop-in" cam, I'm assuming that it will work with my Red pinion gear. Looking for clarification.
If anyone has an EV13, EV27 or stock L-cam in good condition, let me know. Maybe we can work out a deal. Thanks.
Old 06-28-2024, 08:29 PM
98hotrodfatboy's Avatar
98hotrodfatboy
98hotrodfatboy is offline
Received 5,465 Likes on 3,643 Posts
I don't think you'll see a hell of a lot of difference between the Crane cam and the EV 13..
I was able to find this posted 10 years ago by Scott at hillside cycle..
https://www.harley-davidsonforums.co...-a-cam.168570/
daven9113 (06-28-2024)
Old 06-28-2024, 08:33 PM
98hotrodfatboy
Also the cam gear should be fine .
Surprise it didn't have red paint on it..
Old 06-28-2024, 08:45 PM
daven9113's Avatar
daven9113
Thanks hotrod98 for verifying. The cam gear did have red circular ring (outward facing) that denotes it's for an Evo, but I didn't know Crane color coded it. If so, looks like I'm good to go. Big thanks.
98hotrodfatboy (06-28-2024)
Old 06-29-2024, 10:28 AM
BB.No8's Avatar
BB.No8
BB.No8 is offline
Daven, I have a New in the Box EV13 cam that I bought for my brothers bike some years back but he never used it.
Haven't talked with you in quite a while, a lot happened in the last 2 years with my mom. Got the FXR running and p/u a '75 FLH.
Let's get together for a coffee.
The following 2 users liked this post by BB.No8:
daven9113 (06-29-2024), t150vej (07-22-2024)
Old 06-29-2024, 01:09 PM
daven9113's Avatar
daven9113
Hey, it's been a day or two. Congrats on the Shovelhead! Love to see it. I was just at the coffee shop in Cave Creek this morning. A brisk 98 degrees ride home. LOL, Let's link up soon and catch up.
BB.No8 (06-29-2024)
Old 06-29-2024, 02:19 PM
BB.No8's Avatar
BB.No8
BB.No8 is offline
You bet, let me know when you have time.
Old 07-22-2024, 03:28 PM
JG321's Avatar
JG321
JG321 is offline
If you're still looking for a cam, I have an ev23 in good shape.
Old 07-22-2024, 05:59 PM
Dano523's Avatar
Dano523
Dano523 is offline
https://www.revzilla.com/assets/0004/0321/1391.pdf
Forget everything else on the above link, just scroll down to the bottom of page 3, and how to measure your old cam gear with two .108" pins, then call up andrews directly, to order an EV13 cam, with the correct size gears on it (there are like 4 different size cam gears).
This is going to same you a lot of time, if the new cam you get has the wrong size gear on it, and you need to take the cam to a shop to press off the old gear from the old cam, and press it on the new cam.
if you need .104" pins,
https://www.msi-viking.com/Vermont-G...l-Class-ZZ-Pin
As for ev13, great low and mid range for heavy two up touring bikes where the motor is going to spend most of it time, and EV27 with mid and high range, for lighter bikes that you are going to be playing rev ranger most of the motor life instead. Highway speeds, should be in the lower meat of the cam, but putting around town (above motor lugging), engine revs will be too low and will need to run in higher gear burning up more fuel instead to keep engine in meat of cam range.
And just a FYI, but if anyone is going to offering up a cam, then at least measure up the gear on it, so the new op knows if the gear has to be swapped or not, before he can use it on his motor.
Old 07-22-2024, 09:04 PM
Spanners39's Avatar
Spanners39
Spanners39 is offline
I swap cam gears at home and don't use a press; a frying pan and a freezer work well when putting the gear back on. I don't know anybody who has ever measured a cam gear in 45 years of wrenching, they all just swap the old one onto the new cam...crazy that people should ignore the FSM so blatantly...whatever next?
Racepres (08-31-2024)
Quick Reply: Crane Fireball Cam
