2022 SGS - Stiff clutch
Old 06-28-2024, 06:13 AM
MoneyFor's Avatar
MoneyFor
MoneyFor is offline
Default 2022 SGS - Stiff clutch
Just a question and a job that I always postpone for health reasons, usually.
My 2022 SGS has a stiff feeling in the clutch at some point, the first few mm go smoothly when squeezing the clutch lever, then it becomes a bit stiff
and then smooth again. Has this in any gear or rpm /speed. I would suspect a bad cable or a twisted cable somewhere is this something known or
has anyone else experienced this problem? if so what was the solution or problem ?
Old 06-28-2024, 11:39 AM
JamesGilbertAZ's Avatar
JamesGilbertAZ
JamesGilbertAZ is offline
If you feel comfortable enough, perform a proper clutch adjustment and change fluid. If that does not help lets see...
MoneyFor (06-28-2024)
Old 06-28-2024, 12:28 PM
MoneyFor's Avatar
MoneyFor
MoneyFor is offline
Thanks for the reply !
I don't think adjustment of the clutch will be the cause because it works as it should, shifting also goes smoothly, even finding neutral is no problem. It feels more like the
cable or something else has a fixed point, because it is a cable operated clutch, not hydraulic.
So I was wondering if this is a known problem with the M8 SGS or if anyone else has had this too, I have never had this problem with any of my M8 Softails.
Old 06-28-2024, 03:03 PM
cobra23's Avatar
cobra23
cobra23 is offline
Seems like a competent mechanic would need to pull the primary cover and inspect the clutch/clutch basket. Not many of those at Harley dealerships these days.
I would try to find a good Indy who would take the time to try to identify and fix the issue.
Old 06-28-2024, 03:57 PM
btsom's Avatar
btsom
btsom is offline
Have you ever lubed the cable?
Old 06-28-2024, 05:47 PM
Taxgod4u's Avatar
Taxgod4u
Taxgod4u is offline
Received 1,108 Likes on 509 Posts
Is that spring where the 2 cable join hanging up on the cable cover and/or the red buttton sticking out a bit and causing friction?
Old 06-28-2024, 10:26 PM
MoneyFor's Avatar
MoneyFor
MoneyFor is offline
Yes I did
Old 06-28-2024, 10:35 PM
MoneyFor's Avatar
MoneyFor
MoneyFor is offline
I have indeed already checked that, the problem has actually been there since I bought the bike new and perhaps I should have gone back then, but I am not a dealer fan.
Immediately after purchase I replaced the handlebars and also exchanged the levers with those from Rick's. So if I had gone back, that would probably have been the cause
in their diagnosis. I will then start by disassembling the entire cable and see if there is still a fixed point in it, hopefully because that will be an easy fix.
I just hoped that it had been a "common" problem that someone here would say it was this or that
Old Yesterday, 12:15 AM
Hulkss's Avatar
Hulkss
Hulkss is offline
Received 1,890 Likes on 1,000 Posts
Originally Posted by MoneyFor
Yes I did
Some have written that the H-D plastic lined clutch cables are not supposed to be lubed. I'm not sure about that. What's the best lube for an H-D clutch cable? Is it better than no lube?
Old Yesterday, 01:05 AM
MoneyFor's Avatar
MoneyFor
MoneyFor is offline
Based on the "fixed" point in the cable, I lubricated it, I used a silicone based oil for this.
Quick Reply: 2022 SGS - Stiff clutch
