Twin Cam Motors Twin Cam 1998 thru 2017
2005 Electra Glide Rear Rocker Box/Cylinder Removal
Old 06-28-2024, 12:35 AM
Biker_Life_619's Avatar
Biker_Life_619
Biker_Life_619 is offline
Stage III
Default 2005 Electra Glide Rear Rocker Box/Cylinder Removal
Hi All,
New to posting but have been using the forum for years to work on my bikes. I've looked everywhere but have not found what I was looking for so I thought I'd start my own post. I am doing a 95" big bore on my TC 88".It is a fuel injected 2005 ELectra Glide Standard All the videos I have seen and the forums read state that you can remove the rear rocker box and cylinder while the motor is mounted. I have tried every which way but the rocker box bolts are hitting the frame before coming out. I have tried wiggling but it is just to tight. The bolts get jammed and the left rear one just won't clear the hole. I feel that even if I could get it out that putting it back together correctly would even be tougher. Not to mention not being able to torque any of the bolts. Question, is there a way to just lower the motor a little as to not have to remove it. I just don't see any other way. If so, how would I lower the motor. I've done my own cam work and other stuff but this is my first top end job. Thanks in advance for any help you can give. HB
Old 06-28-2024, 03:05 AM
squirrelsnest's Avatar
squirrelsnest
squirrelsnest is online now
Received 5,665 Likes on 2,817 Posts
Welcome to the forum from Virginia..............
Old 06-28-2024, 05:31 AM
Jackie Paper's Avatar
Jackie Paper
Jackie Paper is offline
Received 5,001 Likes on 4,192 Posts
Welcome to the HDFORUM.
I hope you continue to enjoy your ride here to.
Only as a suggestion, by me as a USER, create a signature line similar to my one line on my bike information.
The year, model, and all the letters Harley assigned to the bike. It will appear at the bottom of your post.
Doing this will be helpful if you ask a question. All Harleys aren't the same with many changes and variations over the year.
Of course, you can always add it to any thread with a question.
You can also add any other details you choose and a favorite picture to the signature lines.
If you like, you can also add a favorite picture for an Avatar you see at the top left of all your posts as a postal
PS…Questions would probably get more comments in the proper area using the dropdown menu under Forums in the menu above
It’s possible if a Community Team member sees your post, they may move it to a better area.
If they do, only as a suggestion by me, make another new thread back here in the welcome area to say hello and if desired introduce yourself.
Old 06-28-2024, 06:15 AM
470004's Avatar
470004
470004 is online now
Received 16,303 Likes on 6,745 Posts
Welcome to the forum from New York.
Old 06-28-2024, 10:11 AM
Biker_Life_619
Stage III
Thank you for the welcome. I will also add the information to the signature line. Hope to get som help on this removal as I am suppose to drop these jugs off Tuesday to have bored. Thank again. HB
Old 06-28-2024, 05:12 PM
imoo6170's Avatar
imoo6170
imoo6170 is offline
Moved from the Welcome area - to the Twin Cam Motors section - you will get better technical responses here than in the Welcome section
roussfam's Avatar
roussfam
roussfam is offline
Received 7,220 Likes on 3,753 Posts
The bolt won't clear the rocker. Once you have the bolt unscrewed and loose in the rocker, you take the rocker and the bolt out together.
07UltraGuy (06-28-2024)
Old 06-28-2024, 06:04 PM
Biker_Life_619
Stage III
Default Got it out
I pulled the bolts to the bottom of the rocker box and slid the whole thing out together. I did have to cut down an allen wrench to get it to fit between the frame and bolt. Excited to get the build done.
The following 2 users liked this post by Biker_Life_619:
07UltraGuy (06-28-2024), TexasScooterTrash (06-28-2024)
Old 06-28-2024, 06:22 PM
roussfam's Avatar
roussfam
roussfam is offline
VERY IMPORTANT....you need to make sure there is no oil in the holes when you reinstall the rocker bolts. Blow them out with compressed air or use Q-tips.
Old 06-28-2024, 07:15 PM
MURPHCC1's Avatar
MURPHCC1
MURPHCC1 is offline
Received 2,957 Likes on 1,440 Posts
And theres a special tool to remove those bolts......here's one,,,,,,there are others.
I was always afraid I'd break it off while torquing the bolts down.
https://www.denniskirk.com/v-twin-ma...xoC2_sQAvD_BwE
Quick Reply: 2005 Electra Glide Rear Rocker Box/Cylinder Removal
