Compensator Issues 03 FXDWG
Old 06-22-2024, 08:59 PM
EppsHD's Avatar
EppsHD
EppsHD is offline
Default Compensator Issues 03 FXDWG
Been having some noise what sounds like it's coming from the Primary Case. I took the primary apart, decided to replace the inner primary bearing & race while I was in there( was worn some). Replaced all seals & removed the Compensator to look it over and in the pics you'll see where it's worn down both on the Sprocket and inner shaft . Is this normal or is this typical on Compensators. I may replace it any ways.
Worn on this side
Not worn
Not
Worn
Old 06-22-2024, 09:26 PM
Ohio HD's Avatar
Ohio HD
Ohio HD is offline
I don't see anything that looks concerning. The OEM unit is now only available as individual parts. So about $600 to replace three parts. The early TC compensator is pretty robust.
So how many miles on the bike? What about the condition of the primary chain? They can get noisy when they wear out.
Old 06-22-2024, 11:14 PM
EppsHD's Avatar
EppsHD
EppsHD is offline
Bump
Old 06-22-2024, 11:16 PM
EppsHD's Avatar
EppsHD
EppsHD is offline
Bike has 55000 miles on it. I may go ahead & replace the chain. So I shouldn't be concerned about the worn area shaft ?
Old 06-22-2024, 11:24 PM
Ohio HD's Avatar
Ohio HD
Ohio HD is offline
The photo of the sprocket isn't clear enough to tell the condition of the machined ID. If you're feeling spots that are worn, then maybe replace that sprocket. It's up to you, but I doubt that's the source of your noise.
Old 06-23-2024, 02:46 PM
Max Headflow's Avatar
Max Headflow
Max Headflow is offline
Received 5,652 Likes on 3,856 Posts
The comp is fine.. If anything need examine, post a pic of the rotor inner splines. You may need to trim 0.060" of the crank nut..
djl (06-23-2024)
Old 06-23-2024, 05:25 PM
EppsHD's Avatar
EppsHD
EppsHD is offline
I don't know how your going to see much from this pic without an in person visual look at shaft spline. But here you go.
Old 06-23-2024, 06:22 PM
Max Headflow
The rotor is the the thing that covers the alternator.. That is called the shaft extension..
Old 06-23-2024, 06:52 PM
EppsHD's Avatar
EppsHD
EppsHD is offline
Oh you mean the rotor that covers the "stator".
Old 06-23-2024, 06:55 PM
EppsHD's Avatar
EppsHD
EppsHD is offline
Quick Reply: Compensator Issues 03 FXDWG
